Bench cable to read OBD on 3.8.3 ECU from AGU engine
Discussion in 'Electrical' started by JohnB73, Apr 29, 2024.
  1. JohnB73 New Member
    Hi all, I'm struggling to create a bench cable to simply read any codes stored in my ECU (06A 906 018 CG) (which I believe is the 3.8.3) paired with the Mk4 GTI 1.8T AGU engine. Any pointers would be much appreciated - want to make some progress on this before summer has been and gone again!
    Powering the ECU on Pin 1 & 3 and grounding on Pin2 with the OBD scanner taking power from the +12 and GND and linking the K-Line from Pin 19 on the ECU to pin 7 on the OBD.
    ECU
    Pin 1 : + 12V
    Pin 2 : GND
    Pin 3 : + 12V
    Pin 19 : K-Line (Connected to pin 7 on OBD)
    OBD
    Pin 16 :+ 12V
    Pin 7 : K-Line
    Pin 5 : GND
    Pin 4 : GND
    Am i missing something fundamental, slightly off or way off? OBD Scanner just cannot connect and times out.
    Thanks
    John
  2. PhilRyder
  3. JohnB73 New Member
    Thanks Phil - i'll give him a shout, cheers
