Best tyres for fast road use?
Discussion in 'Wheels and Tyres' started by Savagesam, Jan 10, 2016.
  1. Savagesam
    Thanks for all the suggestions guys, now time to do some reading :thumbup:
  2. RobT
    RobT Forum Junkie
    Cheshire
    Have had 'top end' tyres like Pirelli P Zero, Goodyear Eagle F1, Continental etc, and its hard to really tell any difference. Also recently tried a set of Kumho Ecsta LE Sport, mid range I guess, and most of the time perfectly fine. Only difference I have noticed is grip out of a junction if the road is wet. Once had a car that came with Avon ZZ3, lower price tyre quite often, absolutely terrible. Noisy, poor feel for the road, used to wander around. Never again.
  3. blis Forum Member
    New South Wales
    I had a series of 15" Ecstas deform as the belts failed. Happened to three of the batch.
    I then moved onto Bridgestone Potenzas, LOVE EM!
  4. Finite
    Northamptonshire
    I found this large thread on pistonheads Uniroyal Rainsport 3-Verdict?
    Ultimately I think I may need something else on the warmest days of summer, but they should fit the bill as a right way compromised all seasons tyre. So thanks for the recommendations.
    If anyone does buy URS3 from Camskill let me know how old they are and who the courier is. Hopefully I haven't shot myself in the foot they've been despatched from mytyres now via DPD.
  5. Toyotec
    Not sure what date was on all the tyres sets we had off camskill. I do know they come pretty pronto!
    For the road you should never have to have to push on as hard as you would on a track. UniRS3 will be fine.
    On track, on a dry day, the side walls turn to jello on the UniRS3 and that is when a switch to say a Federal RSR or a A048 makes a 'night and day' difference.
  6. twolitrepinto Forum Member
    Hastings, East Sussex
    I can't rate the Uniroyal rainsports high enough. I use them on my daily.
    I was using toyo proxes T1R's which are very good in the summer and not bad on track but wear quickly. They have a flimsy side wall so they do roll a little and wear the outer edges. I didnt suffer this as i was running -3.0 neg camber at the time.
    I found the rainsports much more predictable all round though. For a rain tyre they are very grippy in the dry also.
    I drive very hard and have so much confidence in the corners no matter what the weather.
    I especially love them in the pouring rain when there is standing water, they disperse big puddles as if they weren't there. MUCH less aquaplaning than others i've used.
    Don't be tempted to use trackday tyres on the road, yes they are grippy in the dry but after a while you will get fed up of the decreased ride quality and tramlining. Also after so many heat cycles they turn hard.
  7. Finite
    Northamptonshire
    My tyres have made it from Lehrte>Leicestershire yesterday so I should find out shortly.
    EDIT: They're 4715 so less than 2 months old.
  8. Finite
    Northamptonshire
    A word of caution about not booking a fitting station in advance with mytyres. I didn't expect 5 per wheel extra for fitting at the same station.
  9. Toyotec
    I get the good guys at Style Dynamics to sort me out with fitting and balancing, when I buy tires from Camskill.
    No good for you in Northampton though.
  10. Finite
    Northamptonshire
    That's handy. I haven't had to do this for a while so I'm starting from scratch again. There's no immediate rush though as I realise I need to correct the camber or pay two tyres worth of adjustments when it's all coming off again later for springs.
  11. Savagesam
    Well it looks like i'll be going for the rainsports, they are recommended by everyone and much cheaper. I've got a few other bits to sort before I order them and then it's off to my dads to get them fitted.
    Does the shelf age really matter that much?
  12. Finite
    Northamptonshire
    If you do a fair amount of monthly miles and tyres don't last you years probably not.
  13. Jon Olds Forum Junkie
    My 1st mk1 GTI (y plate.....) used a pair of MXV's on the front in 6000 miles. They are a consumable, get them worn out....Then try something else.....
    IMHO
    Jon
  14. copeidge
    copeidge Forum Member
    I have to throw in a suggestion
    Nankang NS-2R - Semi slicks
    they are a fantastic tyre! and very very good in the wet, with a B rating which is great espeially form a semi slick, and on track they are brilliant!
    220 ish a set :)
  15. Savagesam
    ^ How long have they lasted you so far? They the ones you took to the ring in your thread?
  16. Finite
    Northamptonshire
    The marketing page says they're a competition drift tyre. What compound did you get 120 or 180/street?
  17. copeidge
    I used the medium 180 compound, yeah these are the ones I went to the ring with. I've done around 1,000 including the ring and one track day. On tyre reviews most people are getting around 8-10,000 road miles out of a set which is awesome!
    I can't rate them enough :)
  18. Muuu New Member
    try Toyo R888 new version or Federal FZ-201, it's slick and legal to street!
  19. Peter Jones Forum Member
    Australia
    My partner alternates between her '79 Golf and '80 Passat for her daily commute.
    Both are fitted with Toyo R888s.
    We get over 2 years out of them them sell them off to a racer once they're worn to the tread bars.
    On the road they never get heat cycled, they just don't get hot enough.
  20. Savagesam
    Them Toyo tyres are more expensive than the ones fasteddie mentioned! damn. I'm not used to everything being so expensive!
    I've had to put them on the side for the time being as other bits have popped up but I think for the time being, not earning a massive amount of money I think I'm going to go for the rainsports, when I can afford them! [:D]
