Boost pipe ends - ideas to stop popping off?
Discussion in 'Turbocharged, Supercharged or Nitrous !' started by daljsd, Feb 25, 2010.
  1. daljsd Forum Member
    How can I stop boost pipes from popping off?
    Is there a special tool to make a ridge/flare on the end for the clip to sit behind?
    example here....
  2. pigbladder Forum Addict
    cambridge , uk
    yes theres a tool for that...theyre v expensive
    how about getting a weld put round them instead
  3. Toyotec
    Or a weld butt every 90 degrees. That is what I have on mine.
  4. steved Forum Member
    What about 4 rivetts
  5. daljsd Forum Member
    ok, ideas sound good.
    I was thinking of making a small ring of the same diameter but cutting it and sliding over the boost pipe then tak it on there.
    how much is expensive for the proper tool?
  6. skoda4x4 Forum Member
    cant a machine shop bead it for you?
  7. pigbladder Forum Addict
    cambridge , uk
  8. Nige
    Nige Paid Member Paid Member
    Mole grips. 3 bits of metal, welder and patience. :thumbup:
    Not my work, a photo from elsewhere that is what you are after ?
  9. pigbladder Forum Addict
    cambridge , uk
    good idea that
  10. tshirt2k
    tshirt2k Forum Junkie
    Herts
    Thats a good homemade tool.
  11. tshirt2k
    Herts
    Not sure it will work with stainless though.
  12. badger5
    nr Glos
    i find it hard to believe those molies turned out that work
    send your pipes to me and i will roll bead on the ends for you 2/end
    up to 1.6mm ally only tho
  13. Admin Guest
    you want to add that to your section Bill:thumbup:
  14. vw_singh Events Team Paid Member
  15. Mook
    Mook Forum Member
    South Coast
    Erm, where does he say that?
  16. tshirt2k
    Herts
    I use those mikalor type clamps and apart from not tightening them up properly at first, They haven't come loose.
    I saw another way to do it using an exaust pipe flaring tool to expand the pipe which is then cut to make a ring. This is slipped onto the end of the pipe and tacked on. I think if pipes are just floating, they can move around and come loose.
  17. vw_singh Events Team Paid Member
    He didn't. But he is sitting next to me in the same lab.
    Gurds
  18. daljsd Forum Member
    That mole grip is a brilliant idea. Exactly what I need
    I'll give it a go :)
