Bringing an old friend back to life..
Discussion in 'Mk2' started by KeithMac, Jul 10, 2018.
  1. KeithMac Forum Junkie
    Kazakhstan
    P e l o l o c k ?.
    Nice work! fixed the pelolock issue ;)
    KeithMac likes this.
  3. KeithMac Forum Junkie
    Kazakhstan
    My pearly dream of just popping in a diff bolt kit has been well and truely shattered, to be fair it was always on the cards.
    All the taper roller bearings need replacing and one synchronised ring looks like it's been fried to death!.
    On a plus side all the roller bearings, gears and shafts look in good order.
    Managed to pull the diff bearings off with my 250mm puller and a bit of make do and mend..
    Need to buy a bearing splitter for the output shaft taper bearings.
    Taking diff into work tomorrow to use the drill press to drill out diff rivets.
    20180727_194603.jpg 20180727_193425.jpg 20180727_200241.jpg 20180727_202950.jpg
    erreesse and DN5 like this.
  4. KeithMac Forum Junkie
    Kazakhstan
    Got a bit busy with other projects but my lad's been on about our Mk2 and he's been a great help today (hopefully he'll be driving it in a few years!).
    Engines out, subframe etc.
    Could do with brake lines all through really, mulling over using AN-3 Braided Teflon lines but we'll see.
    Had a great afternoon with my son, think he's a VW fan now!.
    20220905_133645.jpg 20220905_140148.jpg 20220905_140703.jpg 20220905_145342.jpg 20220905_172753.jpg 20220905_174016.jpg
  5. KeithMac Forum Junkie
    Kazakhstan
    Motoring along now, my daughter "tool lady" has promoted herself to mechanic so she's been helping today too!.
    Subframes etc all cleaned/ prepped and painted in cold galvanising paint.
    The spare gearbox looks a goer for fitting after my lad gave it a good clean.
    Day off tomorrow so probably get all the engine bay cleaned up ready for doing the brake lines etc. Waiting for new Master Cylinder to turn up..
    Ordered some Fine walnut shell and a media blaster to do my inlet manifold and engine parts, seems best least destructive option!.
    20220911_101642.jpg 20220911_132209.jpg 20220911_162123.jpg 20220911_162142.jpg 20220911_162157.jpg 20220911_162149.jpg 20220911_162220.jpg 20220911_134521.jpg
  6. KeithMac Forum Junkie
    Kazakhstan
    Spent 3 hours cleaning the engine bay today. Apart from a little surface rust she's solid as a rock still!.
    Got a bit of painting to do then at least I can get brake lines/ steering rack/ subframe back in.
    20220912_130752.jpg 20220912_130747.jpg 20220912_131022.jpg 20220912_140600.jpg 20220912_140604.jpg 20220912_140606.jpg 20220912_142407.jpg
    Cressa, erreesse and Zender Z20 like this.
  7. KeithMac Forum Junkie
    Kazakhstan
    Had a bit of an issue with my Manual Steering conversion. I thought I could get away with just swapping the rack..
    I've had to buy:
    New Steering UJ.
    New UJ boot (longer than PS).
    New tie rod ends (PS don't fit!).
    Did contemplate stripping and gutting the power steering rack (might still do that later if I get time).
  8. KeithMac Forum Junkie
    Kazakhstan
    Manual vs Power steering UJ's, brake calipers and gave my daughter a head torch!.
    She's helped out every night bless her, a mechanic in the making!.
    These pipes are a bit sketchy, wonder if anyone does aftermarket silicone jobbies?.
  9. KeithMac Forum Junkie
    Kazakhstan
    Just about done with subframe assy, had to make some Half Nuts as VW are NLA?.
    Calipers done.
    Patio's a war zone but getting there..
    20220917_180121.jpg 20220917_200904.jpg 20220918_092157.jpg 20220918_114819.jpg 20220918_114944.jpg
  10. Savagesam
    You have reverted from PAS? Why’s that? Or did my skin read fail me.
    Whoever I bought my PAS from gave me the wrong UJ I found out yesterday:(
  11. KeithMac Forum Junkie
    Kazakhstan
    My PAS Rack and pipes were in a right state, I've gone manual rack to neaten up the engine bay but I've kept the rack just in case.
    Ideally I'd like to go the electric steering column route.
    The PAS UJ is shorter and has a bigger end on the steering rack end.
    The PAS UJ boot is different as well.
  12. KeithMac Forum Junkie
    Kazakhstan
    Kong coilovers getting some needed attention yesterday.
    Had welder our to pull a snapped stud out of cylinder head and my daughter was having a practice while it was out!.
    She's got stuck in with everything.
  13. KeithMac Forum Junkie
    Kazakhstan
    PTFE brake lines this morning, 8 meters doesn't go far!.
    Having wheel well exit rear bulkhead fixings, two nice pipe entries in lhs of engine bay.
    Front wise going PTFE up to the original mounting points then normal wheel well hose.
    My rear Mk4 calipers appear to be M11 fine brake fitting?, not done me any favours today..
    Got some Stainless P clips to secure it in the engine bay.
    20220925_122952.jpg 20220925_122945.jpg 20220925_122941.jpg 20220925_122828.jpg 20220925_120832.jpg 20220925_120829.jpg 20220925_120825.jpg 20220925_112813.jpg
  14. KeithMac Forum Junkie
    Kazakhstan
    But of an update, made some frames and got Golf on Chassis Trollies.
    Rear beam and hangers of, measuring up for wheel stud conversion.
    My new sills arrived (should have used VW Heritage first time around!), was going to just use the bottom section but looking at the quality I'm doing the full sills, more work but better outcome hopefully!.
    Helix Autosport are refurbishing my paddle clutch for £76 + vat due to oil contamination which is a bloomin bargain really!.
    20221002_104023.jpg 20221002_130536.jpg 20221002_153432.jpg 20221003_160517.jpg 20221009_134402.jpg 20221009_142148.jpg 20221010_110028.jpg 20221010_120921.jpg 20221010_141247.jpg 20221011_202742.jpg
  15. KeithMac Forum Junkie
    Kazakhstan
    A few more poc of progress.
    3mm Angle Iron down both sides now, can easily jack car up from middle of sills!.
    20221106_100320.jpg 20221106_103455.jpg 20221106_144103.jpg 20221107_115115.jpg 20221107_135848.jpg 20221107_182327.jpg 20221107_172215.jpg
  16. KeithMac Forum Junkie
    Kazakhstan
    NS finally done and wheel wells sorted out. Rear 1/4 looked a bit iffy bur after welding the holes up without blowing it to bits I'm sure I can salvage it.
    20221114_120527.jpg 20221114_120540.jpg 20221120_130105.jpg 20221120_144248.jpg 20221121_095235.jpg 20221121_102540.jpg 20221121_134009.jpg 20221121_120853.jpg 20221121_123124.jpg
  17. KeithMac Forum Junkie
    Kazakhstan
    Managed to find a new MegaSquirt 1, bought as a spare!.
    Booted my old laptop up, not been turned on for at least 15 years and it booted straight up!.
    Managed to get my original code off the old laptop luckily.
    Got my original MS1 running from a Milwaukee M12 battery, took a while but I've got Megatune running on a Windows 10 laptop with FTDI USB to Serial adapter. Computer happily taking to MS1!. 20221115_174944.jpg 20221115_182552.jpg 20221115_203543.jpg 20221117_182650.jpg 20221117_183720.jpg 20221117_183740.jpg 20221117_183817.jpg 20221119_211732.jpg 20221119_212540.jpg 20221119_210638.jpg
    TonyB and costel1969 like this.
  18. KeithMac Forum Junkie
    Kazakhstan
    Me and my lad have been beavering away and today we got it running again.
    AN-6 Teflon fuel lines, Sytec FPR, Mitsubishi GTO fuel pump and a lot of work!.
    Mechanically and chassis wise we are nearly done.
    Light at the end of the tunnel!.
    https://youtube.com/shorts/MkfbXA9kpr8?feature=share
    costel1969 likes this.
