Can a 16v exhaust system fit an 8v?
Discussion in '16-valve' started by richgit, Aug 14, 2005.
  1. richgit Forum Junkie
    North London
    Selling an entire 16v magnex system on ebay...., someone just bid on it and asked me if it would fit an 8v.
    How is the downpipe designed on an 8v? Does it meet at the same point, and if so, then he can use a reducer pipe if it's a smaller bore?
  2. AlexB Forum Member
    i fitted a stainless 16v exhaust i had lying around to a mates 8v. it went on, but didnt look right, it hung at the wrong angle. perhaps the downpipe sits funny on an 8v
  3. AndyG
    AndyG Forum Member
    Worcestershire
    well for a start the 8v and 16v use different diameter system pipes so you'd need a reducer pipe at least
  4. Jsem Forum Member
    had any of them questions like;
    willing to split, i give ya 20 for the back box.
    Edited by: Jsem
  5. vealige Forum Member
    8V pipe is 53mm and 16V is 57mm if memory serves me correct and the hangers etc are the same on an 8V as they are on a 16V as my old 16V had an 8V Mangex system fitted [:D]
  6. Phil
    Phil Forum Member
    Ont tinternet.
    My 8V has a 16v system fitted, but I think if you are fitting the full system it should bolt straight on. However, if you are fitting a 16v backbox to an existing 8V system a sleeve (reducer) is needed.
  7. richgit Forum Junkie
    North London
    Cool :thumbup:
    And no jsem, havent had any of those silly questions yet ;)
  8. nickvw Forum Member
    10 miles from Castle Combe
    Why Magnex, quite restrictive I beleive [:s]
  9. KeithMac Forum Junkie
    Kazakhstan
    Have you owned one? My car doesn`t fell like it`s been restricted by the exhaust..
  10. nickvw Forum Member
    I have not owned one but I know mates who have and both back up what I said.
    One of the owners took his valver to stealth recently for a set up and Vince himself commented on the very same thing as his exhaust was a magnex...
    Obviously you can't rely on what everyone says, it's down to personal choice on what you prefer at the end of the day..
  11. chrismc Forum Junkie
    Magnex......now where is my long bargepole! ;)
    The big restriction problem is the backbox design...or the rubbish solid downpuipe design
    Early Magnex systems had a straight through design with 2 pipes going thru the backbox which aint too bad, tho it didnt give me a noticeable gain. 16v & 8v systems are seperate too..These systems had the awful solid downpipes tho [:^(] Avoid solid downpipes like the plague
    This design was later dropped due to customer feedback & requests for a quieter system. This system was downpipe back & had a very large bore (2.75") but a multi pass back box & single restrictive pea shooter outlet into whichever tail pipe was chosen...(6x4 Oval, DTM, 3" Straight)
    My early system was swapped for a later design under warranty after it cracked 4 sets of downpipes, but it lost BHP over the old system [xx(]
  12. richgit Forum Junkie
    North London
    this system im selling has the flexi pipes and isnt a ridiculous bore :thumbup: same system paul16v has, and thats a nice sounding and beneficial system to engine gains coupled with other choice mods [:^:]
  13. richgit Forum Junkie
    North London
  14. GVK
    Proper,proper salesman bollox. :lol:
  15. flusted Forum Member
    Kazakhstan
    if you use the 16v downpipe it will bolt staight on
  16. richgit Forum Junkie
    North London
    [8D]
