Fitted a new rad to my car today, and reused the brand new blue coolant that was in there with the old one. Spilt a bit whilst doing it, so i need to top up just a full coolant bottle's worth of coolant. Ive got the better Red Coolant sitting on my shelf, but i was wondering if you could mix blue and red together and its ok, or if you shouldnt mix at all? Edited by: richgit
The older G12 coolant will not mix with G11. However, G12+ will mix with G11 just fine!! Assuming VW coolants being used of course.
as Deako said There was a warning of severe corrosion problems when mixing G11 & G12 in a VW bulletin, said if they were mixed the cooling system must be thoroughly flushed and only one type used (that was before the G12+ was brought out)
Ooh, fair play. The blue stuff is the standard one you get from GSF, and my red one (ready to put in) is 5 star stuff that i got from a warehouse...
VAG probably, and then one of the sheep started declaring that it's got to be best, someone took a bottle to Wolfsburg once Same thing with toyotas, you are only supposed to fill them with Forlife. 14L in an MR2 at about 12 per 5L
