Hi guys, Does anyone know the part number of the nut/bolt and rubber bush that holds the airbox cover in a carb'ed engine? i have a photo and circled the missing area. Thanks in advance.
Double studdy bit mit rubber AV feature - 443 121 273E Washer - N 01166615 Nut - N 01100624 'cording to vagcat.
Cheers Pete. Hahaha - Shaz. This is my secondary airbox which i drilled holes to make it go faster (just kidding).
No worries. Aside from the holey airbox, you seem to be missing the vac hose to the blend flap vacuum motor from the airbox thermostat too. If the flap is inoperative, you'd do well to block off that vac stub of the airbox thermostat, or it'll cause a vac leak whenever the thermostat is colder than 20C.
Ah cheers Pete. Yeah I am missing that vac hose - not too sure where it is. I think I had the holey airbox during winter and get a healthy 35mpg Also I recently passed the 155,000 Miles milestone!!
Driver engines seem to last forever My old 1.8 one had nearly 200,000 on it, and the last i heard it was still going strong!!
You can buy that part here.. http://cgi.ebay.co.uk/VW-GOLF-MK1-M...arts_Vehicles_CarParts_SM&hash=item3366730a04
Wow Rich, 200,000!! Hopefully I get to at least that! Cheers MacColl, I will be ordering that tomorrow, hopefully I will get it before GTi Inters.
