thinking about removing my ce2 fusebox as i'm in the midst of removing what isn't needed and finding alot of space. (plus it needs to be moved for the cage anyway so new looms are being made by a friend from work). has anyone done this? is there anything to bear in mind or that i should avoid? also looking at ditching as many relays as possible aswell.. what should i keep??.. indicators is an obvious one... i'll replace the fuel relay with a switch i've done a search but couldn't find anything that was specific enough for what i plan to do. Cheers in advance.
