Changing oil sump
Discussion in 'Passat' started by Wez, Jan 10, 2011.
  1. WEZ
    Wez Official Friday thread starter
    Anyone know how big a job this is?
    Didn't see a speed bump last night and front end smashed about 2ft into the floor and now engine is completely drained of oil[:^(]
  2. Richard Mk2
    London / Bucks
    Im sure the subframe has to be moved and the engine has to be supported.
    Edit - Just found this which should be useful Wez :thumbup:
    http://www.passatworld.com/forums/showthread.php?t=292154
  3. WEZ
    This is gonna cost me a fortune.
    How many litres of oil do you think I can get away with to whip it 2 minutes down to my mechanic?
    I'd rather not spend 50 auid on 5l which is just going to drain straightaway
  4. danster Forum Addict
    What engine is in your car Wez?
    I got a sump here if it is any use. It is alloy, and part number 058 103 603.
  5. WEZ
    20vt dan, if it fits, i'll have it
  6. danster Forum Addict
    Hmm, got an engine code?
  7. WEZ
    Awt?
    Not sure, they dont use many engine codes in the passat, i'd look it up by i'm stealong the coincils broadband at the mo and it fades in and out
  8. danster Forum Addict
    I think that may be the newer type so mine may not be correct. I have nudged RJ towards this thread. ;)
  9. rubjonny
    zzzzz Wha? oh, part number 058 103 603 is listed to fit ADR and AFY, superceeded by 058 103 603 D and then by 058 103 598 D and then again by 058 103 598 B.
    058 103 598 B is listed for ADR, AFY, APT, ARG but only for chassis numbers up to F 3B-Y-000 001
  10. danster Forum Addict
    Cheers RJ.
    My sump is no use then Wez, your engine is the later type of 06X block.
  11. WEZ
    Any tips on soaking the oil up and getting it off my tyres?
  12. danster Forum Addict
    How bad is the sump broken? If it is not holding oil at all I would not start the vehicle at all as you could trash the engine with no oil pressure. Get it towed to wherever it is going to be fixed.
    Clean up wise, loads of fairy liquid and hot water to get the worst off everything, going to be messy work but that will do in the meantime. A proper steam clean would be the real answer though.
    NB. Do not start the engine if the sump is holed badly. :thumbup:
  13. nealey Forum Junkie
    They are a nightmare, I changed one years ago. Subframe doesnt have to come off completely, I got away with loosening the subframe bolts and then I then partially removed the lower engine mounts and jacked the engine up and it just squeezed past. It was a bit of an awkward squeeze but its doable.
  14. WEZ
    i'm not the work myself, just wanted to know how hard it was, full days labour at mates rates, i should be able to handle that.
    will inform my mate tomorrow he's towing me, best to take precautions even though i think the oil has trickled out, didn't start leaking within 5 minutes of impact, and no warning lights for the 15 mile drive home.
    what would have buggered it was the 2 minutes it was running this morning before warning lights came on [:^(]
