Hi all got a problem with my mk2 digi 8v it is an absolute nightmare to start on the morning and when it does start it runs on 3 cylinders unless you keep it above 1500RPM and if you let it idle it will just stall but when the car is properly warmed up (90 degrees) it will idle fine but once it's warmed up is splutters all most putting me through the windshield !! I've done all the checks like vacuum lines , water temp sensors , changed plugs to bosh super 4 , new bosh HT leads , dizzy cap , rotor arm and I had my cam timing and ignition timing done on a DYNO witch is digree perfect !!! I have no idear what is causing it to run like dirt :/ uv been told it could be fule but is there any way to make sure it is that before I buy pumps and injectors ? any help is gratly appreciate.
start here: http://www.clubgti.com/showthread.php?124949 if the ignition timing wasn't done as described then chances are its not right!
