I`ve got an `89 16v golf with the hazard switch on the dash, do I need a set of clocks (speedo etc) with a sinle connector or 2 connectors? I think the single connector is 90 onwards, is this correct? Cheers!
yes m8, if you have hazard switch on the dash its two plug type, if it is on the steering column its the one plug type, pm me i have a set if you are intrested
