Hi Bill ive got a mk2 20vt running remapped K04 and the clutch has just gone What clutch would you recommend? Current set up is MK4 GTI 5 SPEED GEAR BOX (02J) HELIX PERFORMANCE PRESSURE PLATE HELIX PERFORMANCE 6 PUCK SPRUNG FRICTION PLATE HELIX PERFORMANCE RELEASE BEARING LIGHTENED O2A FLYWHEEL SELF ADJUSTING CLUTCH CABLE Thanks Chris
how long has the helix setup lasted you? it should be ok.... I run SPEC clutch myself.. stage 3 and stage 3+ (currently)
the helix set up has done approx 20,000+ miles but i found the helix set up to be a little harsh. Would a sachs vr6 be able to cope with the power/torque from a remapped k04? ive seen these priced very reasonably
