Coilpack for Standalone Managment
Discussion in 'Throttle bodies & non-OEM ECUs' started by Dub Nutta, Nov 13, 2005.
  1. Dub Nutta Forum Member
    Gold Coast - Australia
    What coil packs using the Ford EDIS-4 wasted spark system will acept standard VW 16v HT lead plugs.
    I have a 16v that will be running DTA or MBE management.
    Also will I require the EDIS-4 ignition module or any form or ignition amp if using a standalone ECU.
  2. GVK
  3. martyn_16v Forum Junkie
    behind the sofa
    Late zetec as gary said or peugeot ones can be used
    Depends if the ecus have biult in ignition drivers or not. Best bet is to look on their website for the specs or ask the supplier.
  4. Dub Nutta Forum Member
    Ok cheers, what are we calling late, 2000>?
  5. GVK
    98-99 ish on, Focus 1600 Zetec, that kinda thing.
    Most of the current cars have the same coil.
  6. altern8 Forum Junkie
    Cocos (Keeling) Islands
    what toothed pully would u use with the ford coil pack
  7. mk1 driver Forum Junkie
    Nottingham
