Cordless soldering iron?
Discussion in 'Tools, Equipment & Fasteners' started by Gareth83, May 3, 2012.
  1. Gareth83 Forum Junkie
    Wales
    Can anyone recommend a cordless soldering iron/gun for basic soldering in and around the engine bay/dash etc?
    I'm assuming gas powered or rechargeable are the only types?
    What is the best tip to use also? It will primarily be used for 1-3mm wire
    Budget 20-30 if possible?
  3. Sam.
    Sam. Forum Member
    I ended up with a Potasol SuperPro 125, it was around 60, but its been great so far even with 6mm wire. Comes with heatshrink/plastic knife/blow torch/hot air gun attachments too!
    They do a cheaper range too which will be really good if the quality is the same as the 125 :thumbup:
  4. Deako Paid Member Paid Member
    ReddiWraps
    Ive got one that i got from HobbyCraft a couple of years ago. Gas, similar to RJs with different tips for plastic cutting as well.
