Corrado ABV: Removing Cams Question
Discussion in 'VR5, VR6 & Wx' started by H5LRW, Jun 30, 2012.
  1. H5LRW Forum Member
    Cheshire/Norfolk
    Good Morning All,
    A typical novice VR owner question here: Can the Cam's be removed without removing the G/box?
    In other words is it possible to access the double chain tensioner for removal?
    Thanks
    Luke
  2. H5LRW Forum Member
    Cheshire/Norfolk
    The answer is yes they can.
  3. lewp91 Forum Member
    Hertfordshire, United Kingdom
    see I've rebuilt an ABV once before however, it was last year and I've done a few engines since then (so it's not exactly fresh in my mind)
    is it possible to do so, and then refit them due to the oil pressure actuated cam chain tensioner slackening off enough?
    or is it not something that can be reassembled and timed with the g/box in place?
  4. H5LRW Forum Member
    Cheshire/Norfolk
    If you remove the bolt and upper tensioner the sprockets can be removed from the cams with the slack in the chain.
    Important to make sure that #1 is a TDC (on the pulley mark) and the cut out on the intermediate shaft can be seen from above.
