Corrado Fog Light question
Discussion in 'Corrado' started by jimmyg, Dec 8, 2011.
  1. jimmyg New Member
    Haslemere
    Hi,
    This might sound like a really stupid question but here goes.
    I tried taking one of the fog lights out to change the bulb and when I disconnected it the part that holds the bulb came away from the light housing. I cannot seem to be able to reconnect the two parts and when i put the light back the bulb rattles around.
    Am I being stupid or is the light broken????
    Cheers,
    I think you can use the light housing from mk2/3 on the corerado lense? can you get some pictures. if so, get mk3 fog lights as they have a much better design than mk2. the back part is all metal rather than plastic. i made a thread on stripping down and rebuilding mk2/3 fog light units if thats any help
  3. CazzaVR New Member
    Maybe have a look at the other one to make sure you've put it back together correctly. Unless something actually snapped, wouldn't have thought it would've broken. They can be quite fiddly!
