I’ve bought myself a cruise control kit to play with, does anyone know where the vacuum pump and ecu module go on a RHD car as I haven’t got any brackets, that’s the one thing I’ve got to fabricate. It’s a 16v and the diaphragm goes on the head with a long rod. I imagine the pump goes in the scuttle somewhere and the ecu under the dash, it’s just where! Vent switches aren’t an issue, I’ve got that sorted.
ecu would be behind the centre console, pump IIRC is on a bracket on top of left chassis leg so I guess you'll need to put it on the driver side so vent pipes reach
Thank you John, I would say leave it on the left and extend the wiring & pipework, what with the engine and air box on the right it will get a bit crammed.
I found pic sites showing as a reference for anyone else if ever needed. You where very close rubjonny
