Cupracraigs MK2 GTI 20v
Discussion in 'Members Gallery' started by cupracraig, Mar 5, 2018.
  1. cupracraig
    South West
    yeah i want to get more involved with some of the ClubGti stuff, i know they did a rolling road session at Badger5 a while back, i'm very keen to get involved int hat next time. If they do big show that would also be good. always good to put faces to names
    I wish I could attend some too, but the small matter of the Irish sea in the middle makes it a tad awkward.
  3. cupracraig
    South West
    and some jizz stain in westminster making life difficult when it comes to Borders!
  4. Savagesam
    Yeah, it’s currently a pain. I’m not sure who sets that kind of thing anymore.
  5. dodgy
    I know Sandford, used to live chapel Allerton near lower weare, and stoke Gifford. My boy lives in Kingswood so was down every couple of weeks, well except this year.
    Moved up here to Halifax 4 years ago, may move back that way in a couple though. Miss it down there.
  6. cupracraig
    South West
    its a nice place in the world, great for the kids with schools and clubs and i have the mendips on my doorstep and Cheddar too, i regularly just go for a drive up the gorge on a weekend when the car is all together
  7. dodgy
    I miss the diverse beaches, landlocked here, love kilve and quantoxhead, and cant beat the tired seaside town of Burnham, many an hour spent there.
    The Gorge is great, we were there last year and saw goats on the rock face. I have upstairs a business card from the little cafe Eidelweiss that my parents kept as it was where they went after their wedding.
    And I miss proper cider.
  8. cupracraig
    South West
    well... its F...ucked it TWednesday
    went out into the garage last night after not wanting to go out.. got my heater down from the shelf and in that coming down, another item fell and has taken a chunk of paint out of my car door. Livid.
    Wiring has progressed more.
    Internal Rage.
  9. Savagesam
    Noooo!! Is it bad?
  10. dodgy
    Did that with the mini, knocked a timing chain cover off the hook on rafters, nice dent and chip just off centre of roof so couldn't even put an aerial there.
    You could always vinyl tiger stripe it, proper 90s style, option.
  11. cupracraig
    South West
    its about the size of a penny.. its a respray job on the door. just mad at myself for going out and woeking on it when i didnt want to, thus making a fuck up
  12. Vinnie Paid Member Paid Member
    Love the Car mate where did you get the wool
  13. cupracraig
    South West
    Vinnie likes this.
  14. Vinnie Paid Member Paid Member
  15. cupracraig
    South West
    Some temporary woes to report
    The car did start up and although it was hunting all over the place (put that down to vac leaks etc etc) so i started to put it back together a little.. ran thw battery cable from the boot to te front, extended the fusebox main live and earth (both to the battery battery), connected it all up and that was all fine.
    Testing again between ecu live pin 1 and earth pin 2 i get 12 volt on ignition and cranking
    ecu pin 3 has permanent live
    fuel pump primes and runs as expected
    Cheked coil pack 1 and it generated spark against the head
    Injectors are firing sequentially on turnover (removed to check spray) this leads me to believe my ECU power and grounds are all good.
    Car turns over on the turn of the key
    But the car does not start!
    @rubjonny any ideas?
    I always remember there being a noise from the engine bay before i changed things, from the throttle module ( i think) doing some self adjustment or something, that does not happen anymore. i wonder if this is part of the problem
    plugs are very wet with fuel..i wonder if i have "flooded it"
  16. dodgy
    Not any help with the non starter, sorry.
    Putting it out there, just thought is it worth putting a fuse in the battery cable close to the battery, just in case, years ago had exhaust clamp manage to touch supply cable on hard acceleration, shorting it out when it eventually melted the insulation, and causing it to lose power and not short, took a while to work out what happened.
    Haven't been out to check, but sure the mgf or tf has big fuse in the run, (battery front, engine rear)
    I probably should have thought of this before your install.
    cupracraig likes this.
  17. Vinnie Paid Member Paid Member
    Tried the maf or coolant sensor just a thought
  18. cupracraig
    South West
    Unplugged the MAF, no joy.. i think i flooded it to be honest.
    I've taken out the spark plugs and injectors and cranked it over loads this morning... i'll let it all evaporate away and try at lunch time.
    what do you mean re the coolant sensor?
  19. cupracraig
    South West
    dried it all out, put it all back together and it started... my son is alseep in the car on the drive though so i will need to wait a bit to start it up and leave it running.... if it will stay running haha!
  20. Mk2daz
    100%
    Vinnie likes this.
