CV joint assembly, spring washer orientation
Discussion in 'Transmission' started by Neil_Ireland, Apr 21, 2023.
  1. Neil_Ireland Forum Member
    Hi all.
    Never did this before so I’m asking the question to be safe rather than sorry lol.
    What orientation do the spring washers sit on the gearbox end of the shaft?
    I bought skf cv joints and the inner joints have two spring washers, a plain and one with teeth to match the splines of the shaft.
    Etka only shows one spring washer fitted, as below. 9 in the diagram.
    This is what I have.
    Thanks!
  2. Neil_Ireland Forum Member
    Actually is etka wrong, I found this pic showing the washer the other way around.
    This makes more sense in my mind.
    Like this.
  3. rubjonny
    yep, from elsa:
    Dished spring
    - Installation position: larger Ø (concave side) contacts constant velocity joint.
    Neil_Ireland likes this.
  4. Neil_Ireland Forum Member
    Thanks, figured that was correct alright. Got them all built up.
