Disc retaining screw - why?!!
Discussion in 'Chassis' started by mr.brown, Nov 13, 2003.
  1. mr.brown
    mr.brown Paid Member Paid Member
    Sunny Surrey
    I think I must have changed front discs on VWs more than ten times and every ffing time the ffing disc retaining/screw is seized! Crap design or do I always buy from idiots who have never heard of copper grease!
    Anyway, today was the first time I had to admit defeat. I had to resort to drilling the ffers out and put the new discs on without the screws.
    Just thought I'd let you know. crap day and all that. But hey, at least my new lights arrived today [:D]
    **Sorry, should have put this in chat section.
    Couldn't we have a "moan" forum.
    **Sorry, should have put that in the "new forum suggestions" forum
    Edited by: mr.brown
  2. Guests Banned
    All its for is to hold the disc in place in the factory while its moving along the line so it's easier for the workers!
  3. DAVE 2227 Forum Junkie
    Easy to remove old screw.After drilling head off it spray it with penetrating oil ,leave for a bit , then drill small hole and use a easy out/screw extractor and there you go.I find it is better if they are in as no bits of sh1t can fall between hub and disc before putting wheel on and the wheel will not run out.
  4. Gambit
    Gambit Paid Member Paid Member
    i dont have any on mine, bit of a pain sometimes locating the stud holes when fitting the wheel, but a lot less hassle than dealing with seized screws!
    Edited by: Gambit
  5. harry_the_cake Forum Junkie
    Antarctica
    I never fit them on mine. Pain in the butt.
  6. mr.brown
    Sunny Surrey
    I phoned up loads of car spares shops and hardware shops regarding some kind of tool such as mentioned above but was met with the telephonic equivalent of a blank look.
    I'd be grateful if you could point me in the right direction.
  7. altern8 Forum Junkie
    Cocos (Keeling) Islands
    halford sell um
  8. The Other Simon Forum Member
  9. mr.brown
    Sunny Surrey
    Cheers. 5.95 p&p though, so I'll wait till I need something else as well - quite like the look of their 6-in-1 trim removal tool...
  10. Drew21 Forum Member
    London
    its worth spending a bit on easy-outs cos if they break you end up having to drill out toughened steel. I got some for about 20 quid and managed to break one in a seized brake caliper bolt. Oh so no fun
  11. KeithMac Forum Junkie
    Kazakhstan
    I bought a set of easy-outs from snap-on, surprisingly cheap (30 ish) and lifetime warrany.
    I drilled my snapped retaining screw out, it was becoming a pain lining the wheel-disk and spacer up, best 10 mins I ever spent!
    If you cover the treads in coppa=-slip it won`t sieze in..
  12. essex_lad Forum Member
    Three cheers for Copperslip, and two fingers to all the monkeys out there who never use it !
  13. jcorallo Forum Member
    My old "impact driver" used to get that sort of thing free quite easily - whereas 3 mins with the wrong shaped cross-head screw-driver would mangle it smooth... [:s]
  14. KeithMac Forum Junkie
    Kazakhstan
    If it`s well siezed in you just snap the head off the screw normally, mine was like it when I bought the car I think..
  15. DAVE 2227 Forum Junkie
    Yep halfords and any decent tool supplier.
  16. veedubnutz Forum Junkie
    Worcester UK
    Dont bother with the screws, the heads always seem to be made out of metal looking plasticine on mine [:s]
  17. SkyRocketeer
    SkyRocketeer Forum Member
    Here be dragns
    Never had a problem in nearly 10 years VW ownership. Oh yeah, they can be tight alright, but with the precision application of brute force, things always come out okay in the end.
    Maybe I'm just lucky...
  18. S1MMA Forum Member
    when I changed the fronts on mine, I used an Allen head countersunk screw, which is about 99999999999999999 times easier to both tighten and loosen, and wont go all corroded and manky like the normal phillips head screws. Cost virtually nothing from my specialist toolshop! Try it!
  19. Pike Forum Member
    I haven't got any retaining screws on my front disks and have never had any problems, there's no way they are load bearing
  20. KeithMac Forum Junkie
    Kazakhstan
    You`ve missed the point, it`s just easier to change the wheels over without f**king about lining the disk holes up..
