Eagle F1 wear rates?
Discussion in 'Wheels and Tyres' started by lewiscypher, Mar 4, 2004.
  1. lewiscypher Forum Member
    just been getting some quotes for eagle f1s since most people on here swear by them
    but my suppplier told mealthough Id find the grip impressive they dont last long( very honest of them)
    whats people experience are they short lived?
    (I know its partly down to driving style etc but overall)
    Cheers
    Chris
  2. Tubthumped Forum Junkie
    Hebden Bridge
    I find they last quite well and i'm a nutter!
    Last about 10 times longer than Toyos!
  3. Admin Guest
    If thats true, think i'll be getting them instead of the toyo proxies i had planned for...
  4. g60 pb Forum Member
    Mine have lasted about 10k :)
    Edited by: g60 pb
  5. lewiscypher Forum Member
    and that includes track use does it?
    not too bad and I would guess yo guys are not exactly "lightfooted"
  6. GVK
    If you want tyres that last, buy Firestones,if you want tyres that grip - get F1s [:D]
    I've had some on the front since November, been on track twice with them so the edges are a bit fecked, but they've still got 3-4mm in the centres, I run a lot of negative camber (2)
    And do a lot of road miles in the car also ;)
    Edited by: G_V_K
  7. AndrewF Forum Addict
    Milton Keynes
    isn't this true tho...
    tyres get worn out when they slide around, so sometimes a softer tyre will last longer as its sliding around less.
  8. VR6Will Forum Member
    ive had both Toyos and F1's both lastest about the same time, and both really good grip! F1s probably a couple quid more expensive for 195/50r15 than the toyos
    am running Toyos at the mo, no complaints!
    both are excellent tyres tho! :thumbup:
  9. KeithMac Forum Junkie
    Kazakhstan
    I`ve had mine for 5k and 1 trackday and they`re fine as well, plenty left (although I`m not a hard road driver).
  10. Tubthumped Forum Junkie
    Hebden Bridge
    I kill road tyres on track -- so not counting track time.
    When i was on Toyo's i was replacing 2 a month!
    These Eagles have been on months now and have LOADS on -- also 2 wet sessions at Mallory.
  11. AndrewF Forum Addict
    Milton Keynes
    i never knew you'd tried f1's?
  12. S1MMA Forum Member
    I've gone through a set of 195/50/15 eagle F1's, they lasted well considering I hammered them, not the softest compound I've ever had, and as ACF says: taking a tyre past its nominal level of grip will drastically reduce its life span - so if you are taking a tyre past its level of grip (say 110% of what its capable of), compared with 80% of grip or another tyre (well within its limits), the one at 110% will wear out much faster than the one at 80%.
    I currently have a set of 215/40/16 eagle F1's, on 7" rims, which are lasting ages as I dont push them to their limit unlike the 195's, but maintain the same speeds around corners.
    Get the F1's, they're better than all other tyres in the wet and above average in the dry, and they last long enough depending on how u treat them. U wont be dissapointed. If you want to go on track, get some track wheels and tyres (probably cheaper than mullering road tyres quickly, in the long run)!
    Edited by: S1MMA
  13. GVK
    Yup, that's we we run used Michelin slicks now on track :)Cheaper than killing road tyres, twice the grip
    (at least)[:D]
    http://www.honeywood0.btinternet.co.uk/mallory/gvk.shtml
    Only downfall to F1s and T1-S is road noise,they're a *lot* noiser than the A539s I used to run
    Edited by: G_V_K
  14. vw_singh Events Team Paid Member
    I was also told that michelin pilots are also good tyres?
    What do you thinkk guys?
  15. AndrewF Forum Addict
    Milton Keynes
    no no no...michelin pilots are awful, they're ok in cornering grip but no good under traction and breaking. i had a set in between uniroyal rallye540's and the current yoko 539/pirelli 6000 (i think) set up...and the michelins were the worst, uniroyals were best (awesome in wet)
  16. vw_singh Events Team Paid Member
    MMmmmm.... Eagle F1's it is then. What kinda prices are you peeps paying though? I am trying to get 195/45/15's. I am looking between 70 & 80 per tyre at the mo...
  17. jc.. Forum Member
    Virgin Islands
    55 tops although 195/50/15 are easier to come by
    topgear and blackcircles .com
  18. vw_singh Events Team Paid Member
    Cheers jc, good prices from black circles and i know Topgear so i will give him a call when i need them. ;)
  19. alexc Forum Member
    For those near to London or Berkshire I use Bracknell Tyre & Battery, they can do the F1s in 195/45/15 for about 50 a corner including fit, valve & balance.
    01344 411323
    Ask for Laurence, tell him Alex sent you! :)
  20. g60 pb Forum Member
    Thats a good price, think I paid 60 a piece for my 195/45 R15 GSD3's fitted and balanced
