Eaiest Way to remove a16v mk2 golf engine
Discussion in 'Engines' started by altern8, Oct 23, 2003.
  1. altern8 Forum Junkie
    Cocos (Keeling) Islands
    Whats the easiest and quickest way to remove a 16v engine from a mk2 golf.
    When ever removing the engine the hardest bit is always the zaust manifold but we never know which is the best way to remove the engine complete as one unit.
  2. veedubber Forum Member
    Solihull
    take the front off,
    undo the ancillaries
    jack up the car and put a trolley under the engine, undo the front crossmember, under the engine at its rear mounts, then roll it out.
    I did it with mine a few times, took me 20mins by myself, and it didn't scratch any of the paint work
    :-) Veedubber
  3. alex9107 Forum Member
    silly answer" fork lift track and chains.
    sensible .
    bonnet off disconect everything hook up some chains and straight out the top you will need to let the gearbox tilt down quite a bit [:D]
  4. veedubber Forum Member
    Solihull
    i have craned a few out, i always think its way harder
    :-) Veedubber
  5. destructiv dave Forum Member
    go with veedubbers plan. Front panel off and wheel it out. Hell you can even undo the struts and unbolt the subframe and wheel the whole thing (engine, box, steering, hubs etc.) out if you feel really ambitious.
  6. harry_the_cake Forum Junkie
    Antarctica
    Deffo take the front off. You can get to everything much easier.
  7. GVK
    Really easy to do it this way, especially when you've got a handy cordless impact wrench.. wow!! :clap:
  8. altern8 Forum Junkie
    the way we done it was everything incl the sub frame and steering rack the lot suppenion and all took us bloody ages [xx(]
