Early mk2 gti EV 8v timing check
Discussion in '8-valve' started by Cressa, Apr 16, 2022.
  1. Cressa Paid Member Paid Member
    So, I am the stage of slowly marking up and dismantling to get the engine out and thought I would have a look at my timing.
    I have NEVER faffed with the timing as I thought it needed witchcraft to understand.
    Couple of questions in here...
    • I set the camshaft sprocket mark level to the top of the cylinder head ( or should it be to the head or the rocker cover?)
    • I set the crankshaft by lining up the notch very close to the mark on the plastic cover, and it was TDC via the gearbox inspection hole
    • The dizzy was pointing to No.1 lead.
    All looks good, but after removing the bottom cambelt cover and accessing the intermediate shaft, this doesnt seem to line up with anything.
    Do I just ignore this or is there something else I am missing
    Apologies for the bad angle pictures
    So it lined up until you took the cover off?
  3. Cressa Paid Member Paid Member
    Well it all lined up happy and I left it like that. Then I took the bottom cover off expecting to see a mark on the intermediate shaft lining up with crankshaft pulley, but no no no.... I see a mark on that pulley and it is about 90° out !!
  4. Tristan
    Oh ok.
    It's not a huge issue tbh.
    While it's considered best practice to use all of the marks, really only the cam vs crank are critical.
    The IM shaft can be out, as you can offset that by either removing the dizzy and moving it a spline or 3, or by rotating the dizzy itself.
    So that's probably what happened in your case.
    You can drop off the cam belt and "fix" it, and then rotate the dizzy to suit the new position.
  5. Cressa Paid Member Paid Member
    Thanks for your help with this
    I may just try that b4 it is all in a thousand pieces. I had read some threads saying the same sort of thing
    make sure you get the green bung out before you go any further, pretty hard to set ign timing with it in
  7. Cressa Paid Member Paid Member
    Thanks rubjonny. I had the plug out. What tool do you use to actually use to remove the green part. I have read it is 27mm but unsure and would like not to break it.
  8. rubjonny
    yeah iirc its 27mm, I just tapped it loose with hammer and drift tbh :lol:
  9. Cressa Paid Member Paid Member
    I've just found something that fits really well. The wheel bolt wrench... only slightly smaller but worked a treat 20220421_094802.jpg
  10. rubjonny
    Damn wish I'd thought of that I was there for ages :lol:
  11. daNpy Forum Member
    NL
    That's a good idea indeed.
    Maybe you can fill the "nut" with a cloth or thin rubber thingy so there is even less to none play around the tool.
  12. Cressa Paid Member Paid Member
    Just tried it with a cloth perfect fit
    daNpy likes this.
