We carry a wide variety of engine internals for whatever combination you can think of ,whether it is a stock OEM rebuild or a full blown stroker set up.We got the job for it all.
hello Currently in the process of starting a 1.8 turbo project. AGU with K04 turbo. I'm after conrods, shells etc. if you have any available could you please PM me with details including price, and delivery (UK). Cheers
ABF engine, also can you tell me whats the difference between standard vs undercut head bolts and when and why they would be used?
Yup we got them. On the undercut studs the diameter of the unthreaded portion between the studs is smaller than the overall diameter i.e. an M11 stud would have an undercut portion of say 10mm. That being said we only recommend undercut studs if you are looking for an OEM replacement that is reusable. If you are looking for a performance stud for turbocharged/supercharged applications then always go standard as they will have an 11mm body diameter throughout.
