Exhaust clamp 16v/vr6 2.25in
Discussion in 'Mk3' started by MJA, Oct 18, 2022.
  1. MJA
    MJA Paid Member Paid Member
    that clamp is used for joining 2 pipes which are the same diameter together so isn't suitable for a MK2/Corrado type as they have one pipe larger diameter which slips over the other.
    assuming its a standard cat on your car you need 357253143B -> 1H0253139D - 59.5mm which is £21+VAT at VW or plenty on ebay:
    https://www.ebay.co.uk/itm/363929903970 - pattern
    https://www.ebay.co.uk/itm/173744353628 - genuine
  3. rubjonny
    actually just spotted this is in the MK3 section sorry :lol:
    so yeah for MK3 8v/16v/vr6 you need double clamp 357253141A, 55mm at 31+VAT so that one you linked to will be fine, or a genuine one:
    https://www.ebay.co.uk/itm/175241933716
    MJA likes this.
  4. MJA
    Cheers matey yeah its the mk3 16v. I need to get bits so I can get it put back together. Probably need to venture into my loft and double check the miltek is the same diameter as the cat pipe and stop being lazy [:D]
    Also would you advise exhaust assembly paste as well as brackets?
  5. MJA
    That's still helpful re the other clamps as I need one also to bolt back box to centre pipe which is slip over
    MJA likes this.
  7. MJA
  8. MJA
    Ignore me gone for a custom clamp
  9. rubjonny
    yeah just need to source a suitable adaptor, the jetex system comes with one. just make sure you use the right measurements, I ordered a 2.25" -> 2.5" adaptor since everyone says the 16v is 2.25". but its not as VW use metric measurements so it didnt it :lol:
