fastest out of standard 8 valve
Discussion in 'Transmission' started by cros40, Sep 23, 2005.
  1. octane Forum Junkie
    and he was in a 30 zone...
  2. cros40 Forum Member
    really no mention, [:s]
  3. JEZ
    Jez Forum Member
    My second 8v digi would hit the limiter in top gear on a level road :)
    That's with 195/50 r15 tyres.
  4. Bundles Forum Junkie
    Aberdeenshire
    Touched an indicated 125mph in my Mk3 8v if that counts, lol.
  5. chopperoli Forum Member
    Scirocco Mk1
    My weber carbed 1.8 GU got me to anindicated 120mph on the clocks, would like to know what actual speed was tho, GPS or something! theres bound to be a difference! (it was on a private road obviously!!). Thats with 185/60/14s
  6. GVK
    My Road Angel shows about 5 mph less than indicated speed.
    Also, when we did the Bruntingthorpe Golf+ thrash the Road Angel showed exactly the same speed as the Golf+'s Datron Vbox GPS timing gear [8D]
  7. puffy New Member
    This is my second golf gti 8v, the first was a '87 5dr and that would not go over 110 no matter how hard I tried, however my current GTi as a few people have said feels a lot more free and loose then the other engine, pulls strong in every gear and will hit the 120mph mark on the dials easily enough, never carried on to see if it goes any further, but to be honest when do we do those sorts of speeds?
    All I look for is a fun factor around town, good handling and brakes and something that isnt a slouch, which thegti certainly is not. ;)
  8. Georgezippybung New Member
    Never done more than 70 officer (in 3rd.... :p )
    Careful about what you admit to on here or the road safety facists will be after you.
    Edited by: Georgezippybung
  9. Dub Dave Forum Member
    why does it matter? Me and the missus were discussing this whislt watching 5th gear. I dont care if it does 100...its how quick it gets there.
  10. gillm
    gillm ***** User
    yeovil somerset
    mine hits the limiter in 5th easy :)
  11. GolfBryan Forum Member
    Scotland
    130 in my old digi but speedo was prob way off!
  12. jc.. Forum Member
    Virgin Islands
    120mph 89 8v digi, 3 door.
    Downhill, wind behind, leaning forward and bouncing up and down.
    Brown pants fast in a car that was as unstable as mine!!
  13. octane Forum Junkie
    i've done 70... in 2nd, 110 in 3rd, 130 in 4th and 145 in 5th :)
    Got there in f**k all time too :)
    Edited by: Jettas
  14. luke w
    luke w Forum Junkie
    Cornwall
    You can achieve a better top end with a 4+e box as fitted to the 1.8 carb models. On my old 120mph clocks I had the needle touching the reset odometer button, but with my 160mph clocks I've seen it read 130mph at just under 6000rpm.
    Managed to take this picture off the clock.
    People will probably say its been done of axle stands or something, but it was actually on the ground.
  15. gillm
    gillm ***** User
    yeovil somerset
    kept quite cool too
  16. Phil. Forum Junkie
    Northern Ireland
    I was just gonna say have you changed the clocks coz on my 1990 digi the numbers only go to 120!
    Out of interest ive had it off the clocks plenty of times 5th gear at 6000rpm going to the Ulster Rally most recently.. Didn't let it run to the limiter though.
    Whats the ratios of the 020 box? id like to work out the theoretical top speed.
  17. Bundles Forum Junkie
    Aberdeenshire
    I know on mk1 golfs and early Scirocco GTI's they were s'posed to do
    20mph for every 1krpm in top, my scirocco hit the 6700krpm limiter in
    top almost every night/morning on the way home from work (not a
    standard engine though).
    137mph i worked it out as, the speedo needle had a constant bend in it from always hitting the odo reset knob [:D]
