Mk2 BAM conversion. I have installed a DBW pedal adaptor. It mounts the the bottom of the pedal box via 2x M8 nuts. The pedal is in the correct position and level with the brake and clutch pedal. The issue that I have is the the potentiometer part of the pedal now fouls the fuse box. Looks like I'm going to have to reposition the fusebox.
I think we have just had the same issue. On the side of the fusebox is a plastic plate which slots onto the side of the fusebox. If you remove that there is enough clearance. However, I will double check with my son who has actually done the work.
Right, just checked. The plastic panel is not on the fusebox but on the pedal cluster. I’ll get a picture of it later.
