Hi, Trying to fix the new 4 branch up. Struggling with flexi-pipe setup like the one below I bought one WAY too big and swapped it for a 45mm one. This is exactly the same size as the pipe so won't fit inside or outside! I can't find a 43/4mm one to slot inside the pipe, or a 46/7mm one to slot over Should the pipe fit inside the flexi? I hope this makes a bit of sense! As I've said before....exhausts are not our strong point.
Yes, the pipe should fit inside the flexi piece. Try speaking to Pipewerx. They can supply any piece of exhaust to your requirements. www.pipewerx.com
Thanks....I might re-look at the 45mm one I have. It's possible that it's such a tight fit I thought it was wrong. Also I was trying to slot it over the flexi pipe
