Flywheel bolts Upgrade Please ??
Discussion in 'Transmission' started by ianb, Mar 22, 2004.
  1. VR6Will Forum Member
    good point Gary, i was thinkin bout the six that hold the pressure plate to the crank!
  2. ianb Forum Member
    ARP contacted for more info on their products so I'll let you know
    Should be ordering what I can for safeguarding the old girl.
    Ianb
  3. GVK
    which bolts????
  4. badger5
    nr Glos
    Doweled my man... doweled.. on the race engines.
    Back to front clutch does'nt help the load on the 16v setup. Outboard v.heavy weight compared to conventional setups.
  5. madmk4 Forum Member
    Bill has a good point.
    Double Dowled cranks to flywheel is the best way to go, I dont think TSR will be able to do that though.
    The place I work for does it from time to time....
    Is your crank standard Ian ?, if its been tuftrided or similaly treated, you'll have hell of a hard time drilling the holes for the dowles !!
    A lathe won't touch it !!
    If im not mistaken, its kent or piper cams who do a great deal of arp stuff in the UK.
    Edited by: madmk4
  6. TheSecondComing Forum Addict
    Or order them from the US and take advantage of the exchange rate..... [:?:]
