Forged 06A 1.8T Engine Build Pictorial Guide, (Now Mapped for running in :) )
Discussion in '1.8 & 1.8T' started by sambo, Jun 21, 2012.
  1. sambo Paid Member Paid Member
    Over next few days i shall create a thread about forged 1.8t engine build with 100+ pictures which should hopefully help others who are about to undertake same task:)
    Spec below
    Low mileage Bam Block ,Honed bores
    Forged Oem crank with Pegged crank cambelt pulley
    Fluidampr Crank Damper Pulley
    Gates racing Kevlar Cambelt
    IE Steel rods with riffle drilling
    Acl coated race bearings
    JE Pistons
    Large port head, ported polished flow matched by a retired engine builder who now does heads for Rosten Performance, 1st class
    Full ValveTrain Inconel valves, dual springs, Titanium retainers
    Standard cams(Schricks to fit once engine run in)
    Arp Head, Rods, Crank/Camshaft Pulleys Bolts
    Baffled ally sump
    Will run
    Garrett GT3076R
    Tubular Exhaust Manifold
    Tial 44mm Wastegate
    Tial 50mm Bov
    ProAlloy I/C
    Mocal oil cooler with thermostatic sandwich plate
    830cc Injectors
    RMR Billet Inlet manifold
    Nira Motorsport I3+ Management
    NGK Irridium Spark Plugs
    Hitachi Coilpacks
    All new Gaskets, Seals etc
    During the build Bearings clearances are plastigauged, Piston rings were Gapped etc etc
    Lots of parts ready to fit
    Finished engine as it is now but full pictorial guide to follow
    And yes i have built it in my dining room as i deemed it cleaner then my dusty garagelol
  2. dsj20v Forum Member
    sunny hampshire
    U sir are a star starting mine weekend, like to c and hear experiences of gapping rings? What did u gap to 16/18/16? bare block now ready for ie rods/forged pistons/etc and am a little pensive gapping rings as never done that before
  3. sambo Paid Member Paid Member
    My engine will run quite a bit of boost and maybe squirt of nos so i have gapped mine at 18/20/16 as there will be quite high temperatures in there and cylinder pressure
    Patience is the key and be carefull when grinding to achieve parallel ends so they will close prperly and only grind one side so you have other one thats perfect to check against
    Do not use power tools just use thin cutting disk and spin it by hand against the ring side face inwards and make sure sides are not sharp when inserting it into the bore to check to avoid scratching it
    By the way what tool you using to hone the bores with?
    Here is a quick pic or two gapping
    Il post pictures tmrw of tools i used and will start on this thread properly
  4. sparrow Paid Member Paid Member
    Leamington Spa
    :thumbup: I'd get divorced if I tried that. lol
  5. sambo Paid Member Paid Member
    I have mega forgiving mrs :)
  6. sambo Paid Member Paid Member
    So first thing i have done is strip the block of all bolt ons and give it a thorough clean/degrease and wire brush in places and then etch primed it
    After that i have painted it with silver enamel engine paint, gone for silver as i want to be able to spot any fluid leaks easily
    Soon after discovered that enamel paint was not solvent proof untill it has been baked for some time at over 200* so i shoved it in my oven and did just that!
    Then it was time to hone the bores. After some investigation into what tool is best to use i went for Flex Hone tool with Silicon Carbide abrasive balls in 240 grit
    This tool is self centering and abarasive balls are self susspending for even pressure and give real good finish with correct cross hatch pattern but you will need a drill with about 700-750 rpm and also lower speed setting of around 250-300 rpm
    Once you have honed bores in clock wise and anti-clock wise direction on higher speed repeat on lower speed
    It is important to have the tool spining as you are inserting it and withdrawing it and also should be lubed up with Atf oil
    Once its done it will need thorough cleaning with lots of soapy warm water and wipe with lint free cloth
    Few pics
    It is very important to get correct finish and cross hatch pattern with lines crossing at around 35*-45* to ensure rings will bed in correctly
  7. sambo Paid Member Paid Member
    Once the block has been painted, honed, thoroughly cleaned it can go on a stand so rebuild can begin :)
    First thing to fit is under piston oil squirters
    I had 2 sets Agu ones and Bam ones which were different so i went with Agu ones
    Then on to installing main crank shells genuine Vag ones
    Assembly lube i have used is Redline new product which seems very good indeed and is obviously very important to prevent any damage to surfaces untill engine oil pressure has built up in initial start up
    Make sure all surfaces are lubed up prior to install
    Pay attention not to mix up mains caps
    I have decided to peg my crank cambelt pulley due to running uprated valve springs coupled with kevlar cambelt which is 5 times stronger and also crank and cam pulley are both clamped by Arp bolts
    Also make sure to use brand new mains caps bolts as they are strech bolts. Either genuine vag or uprated Arp studs up to you. I have gone with Oem as i know of 2 engines running 600+ bhp without issues
    Crank dropped in and torqued up, pls excuse poor phone picture
  8. sambo Paid Member Paid Member
    Next stop is installing rods and pistons
    This is quite time consuming and labourious stage as well as quite fiddly at times due to piston rings gapping procedure, rings to pistons assembly, wrist pins circlips etc etc
    But very important to get it right and avoid possible rings failure/breaking ruining your fresh bottom end!
    IE rods with riffle drilling to improve wrist pin lubrication as engine will see sustained high revs
    JE pistons 8.5-1 cr
    Once i have gapped all the rings i have kept them in respective order and also have marked all coressponding parts pistons, rods, wrist pins etc to make sure it all goes together where it should
    Piston rings compressor and expander install tool pictured
    Take care when inserting pistons not to damage rings or bores
    I have plastigauged my rod bearings clearances just for piece of mind
    Then caps were torqued up using arp lube, must do the bolts up and undo 3 times to achive correct torque
    All pistons in, look amasing :)
  9. nut 20v
    nut 20v CGTI Regional Host - Birmingham & Midlands
    Overtaking you
    Wow makes me want to get my credit card out and buy all the parts for my build. :thumbup:
  10. sambo Paid Member Paid Member
    Oil pump chain and tensioner installed followed by oil pump and Crank seals using Dirco sealant to prevent any oil leaks
    Apply sealant carefully so not to overspill to much inside, i think this is acceptable
  11. sambo Paid Member Paid Member
    Go for it!
    Expensive do thats for sure but i hardly go out anymore now im an old fart so what the hell ey, its very satisfying putting it together :)
  12. sambo Paid Member Paid Member
    Cylinder head next
    Dont have any pics during assembly but here is few of the head fully assembled ready to bolt on
    Standard cams in there at the moment as i want to run the engine in first in my standard Agu A3
    Once engine has 1000 miles on it Schrick cams will go in together with GT3076R and lots of boost!
    A very big torque wrench mada bolting the head up and torquing the Arp bolts an easy job as they are tight!
    Follewd by Fluidampr Crank pulley, water pump, Tensioner etc then timing up the Cambelt
  13. dsj20v Forum Member
    sunny hampshire
    How come u stuck with oem tensioner and not gone manual
  14. benny Forum Member
    Looking great Sam! Is that the 3076 I got / had? Fluidampr :drool:
  15. Toyotec
    Great stuff Sam!!
  16. sambo Paid Member Paid Member
    Never had issue with one but am aware they can fail however still enough tension to prevent belt slipping so should be right
  17. sambo Paid Member Paid Member
    Yea thats the one Chris, soon to be boosting its t i t s off! Dampr is a quality item for sure and hopefully will help :)
  18. sambo Paid Member Paid Member
    Cheers Eddie, hopefully a good one and should make decent power reliably
  19. sambo Paid Member Paid Member
    Sump is in for baffles to be welded then the build is complete and should be fitted this coming month
    Diy baffles just want tacking in
    As it is now awaiting its temporary home for running in :)
  20. Toyotec
    Sounds like good stuff Sam.
    By the I know where there is a good AX53B Huffer...
