Front bumper removal, MK2 Golf. How??
Discussion in 'Styling, Trim and Bodywork' started by ASHLEY G, Jul 8, 2007.
  1. ASHLEY G New Member
    Can anyone tell Me how to remove the front bumper on a MK2 Golf? It's the big bumper type. Cheers! :)
  2. nealey Forum Junkie
    4 19mm bolts, 2 either side, undo them, pull bumper forward and disconnect indicators and fogs. Job done
  3. ASHLEY G New Member
    Where are these bolts mate? Are they under the wheel arches? :)
  4. PaulM Forum Member
    doesn't the bumper help support the engine? make sure you have a jack or some support under the sump/gearbox first
  5. mk1steve Forum Member
    swindon
    the 4 bolts are roughly in line with the front indicators
    lie on your back and you should see them clearly
    and yeah they support the engine so put some wood or the jack under the engine
  6. AndrewF Forum Addict
    Milton Keynes
    No need to support engine, its held by another 4 bolts
  7. nealey Forum Junkie
    ive never had a problem when removing a bumper, there are a couple of 13mm bolts that hold the front end on as well which shouldnt be removed without some kind of support
  8. loadsavalves
    loadsavalves Forum Member
    West Sussex
    The bolts you need to undo are 17mm and there's four of them.
    As Andrew said no need to support the engine as the cross members held on by another two 13mm (iirc) bolts.
  9. AndrewF Forum Addict
    Milton Keynes
    and two more 16mm bolts (tho they may hold the other part of xmember actually)
  10. ASHLEY G New Member
    Done! Cheers guys! :)
  11. DN5
    DN5 Paid Member Paid Member
    Doncaster
    Just to confirm...support the engine!
    Unless of course you're car is totally rust and rot free...
    Made the mistake this morning and the front crossmember gave way!!
  12. blis Forum Member
    New South Wales
    Its easier to undo the two screws holding indicators and release them if doing it alone and if you have fog lights disconnect them too
    PS.. the bumper bolts are recessed in holes, the exposed b9lt holds the k frame, do not undo it.
  13. rubjonny
    as above, if its the first time you have removed the bumper support the crossmember. and even if it isn't, still a good idea! the bolts that hold the engien crossmember up are small, and tyhe captive nuts that they screw into are supported by very thin steel on the radiator carrier. Case in point, my mate had his bumper a fair few times but the last time I came to do it the rad carrier split at the captive nut and almost broke my arm. luckily for me the hooked bit on the rad carrier caught it
  14. blis Forum Member
    New South Wales
    You got me worried now!
