yes..... whats the problem?? get new filter, take out all of rubber bungs, remove the 2 rubber pipes, on left? remove metal "Micky mouse" clip (as in the ears) wiggle unit out, remove filter drain off 70-50% of diesel into a container then allow the rest to drain into new filter (via Micky mouse hole) put it all together & start the car & allow to run for couple minutes, it may cut out, but will restart Sound right??
almost as easy as the citroen zx/xantia 'element' filters! undo four 7mm allens, lid off,new element in,lid on, allens back in,prime.
