G60 Turbo !!
Discussion in '8-valve' started by dukhqan, Aug 16, 2008.
  1. dukhqan Forum Member
    Do you recommend to replace the G-lader with a turbo in the G60?
    Will it deliver more power?
    Can it handle 1.4 Bar or more?
    what is the Bhp and Torque with 1.4 Boost?
    Is there any other modifications on G60 with turbo to improve it's power?!
    Thanks in advance
  2. dukhqan Forum Member
    Still no one got an answer!!!! [8(]
  3. dukhqan Forum Member
    Am aiming to work on a standard engine no internal modifications for the currents stage, so lets call it G60 turbo for a "standard engine", so I want the maximum power from the G60 engine and turbo.
    So what do you recommend?!?
  4. Matt82
    Matt82 Forum Addict
    in theory youll get more power from the same boost as the turbo will have no parasitic effect, but seriously, there are hundreds of variables, hence youve had no answers
  5. dukhqan Forum Member
    Well am aiming for 300+Bhp on standard G60 engine, am thinking in installing the Subaru Impreza 2000 Turbo for it's avilability where I live, with a big Intercooler and 1.4 or 1.5 BAR on it, and modified fuel management system.
    So is that achievable in my case? or what do recommend to achieve the 300Bhp!!!
  6. LregG
    LregG Paid Member Paid Member
    Chasing figures is a bit of a fools game mate, don't bother, instead do a lot of research on turbo's and even more research on manifolds available as this may well be a limiting factor on turbo choice available to you
    The trouble with turbo'ing the G60 enghine is the fact that it is counterflow design meaning that the very hot exhaust manifold sits right beside the inlet manifold which is not ideal in a turbo application and it really doesn't help with flow through the engine.
    A 20vt with a ko4 will make circa 280bhp when remapped and will give a lot more torque than a turbo'd G60 will give due to the head design among other factors, something to think about
  7. smillsey Forum Member
    a glader setup can get 200+ bhp.
    why would you ruin a g60 block by whacking a supercharger on it?>
    Just go 16v turbo if you want a different vw turbo.
    the g60 was built to be admired [:$]
  8. dukhqan Forum Member
    G60 is a well built engine, and in my case in limitation of the car, the G60 turbo is my best project, as it's parts availably , i can go for 20VT but for what cost?!?!? :clap:
    Heat shields can be used though.
  9. LregG
    by all means go for it, i was talking ideals mate.
    one thing i would recommend would be to run a boost sense switch instead of the WOT (wide open throttle) switch found on the on the throttle body. This will stop loads of fuel being pumped in before the turbo has spooled hindering spool up time.
    I ran one on my turbo'd G40 engine and it made a world of difference, set it to around 6psi
  10. VR6T
    VR6T Forum Member
    I am just about ready to get mine on the road, i am running a T3 with a original MK1 Turbo Tech manifold and currently using the stock Rallye ECU. Was planning to run 1 bar to see how it gets on and then take it from there...
  11. Matt82
    Matt82 Forum Addict
    one of the guys who comes along to the essex meets has a mk1 with a g60, minus the SC, plus a turbo
    he claims to be in the region of 270-280bhp ( cant remember for sure). he doesnt post on here, but when we see him next ill ask what he has
  12. krazykev Forum Member
    Anything over a bar is a bit of a danger area especially with standard pistons.
    We're running 310bhp at 1.3 bar on a heavilly modified engine reliably.
    Big Valve Ported Head, Forged Pistons (1.9L), H-Beam Rods, Jabba Exhaust Manifold, VF23 Turbocharger, 440cc injectors, 16v fuel pump etc etc.
    Stock map sensor doesnt read too much over a bar either, we upgrade the map sensor within the ecu so it can read up to 1.5 bar.
  13. dukhqan Forum Member
    please will u list me all of ur modifications!!!!
  14. LregG
    I may be wrong by saying this but isn't the map sensor in the rallye ecu's 250kpa meaning they can read 1.5 bar over atmospheric??
  15. VR6T
    VR6T Forum Member
    I hope so as thats the ECU i am usuing on my G60T setup...
  16. dukhqan Forum Member
    Is there any Stroker kit for the G60?!
  17. prof Forum Addict
    would be loads easier to just use a bigger charger on the g60, eaton m90?
  18. dukhqan Forum Member
    am planning to use the IHI turbo instead, so am looking now for a stroker kit for the G60
  19. prof Forum Addict
    but the head is the main limiting factor....
  20. dukhqan Forum Member
    it's all solved for the inlet and outlet issue
    Any STROKER KIT for G60??
