Gear stick not centring - FIXED
Discussion in 'Transmission' started by Danallkins, Mar 20, 2014.
  1. Danallkins
    Danallkins Forum Member
    Deal, Kent
    My gear stick on my Anni (6 speed) won't self centre.
    I changed the bush at the bottom of the great stick last year.
    I hadn't driven my car for a couple of weeks when I noticed it wouldn't centre.
    To try and fix this I replaced the cable end bushes this week with 42 draft design CNC bushes but it hasn't helped.
    Does anyone have any ideas?
  2. GVK
    There's a spring on the shifter that does the self-centering, probably broken.
    My shifter was from a 6 speed 02M can see the spring on the left hand side of the lever here :
  3. GVK
    No 19 on this pic.
    Mk1 Ford Focus has a similar spring that's prone for snapping,changed a few of those!
  4. Danallkins
    Deal, Kent
    Thanks. That was my next item to check.
    Number 25 in this image I think.
  5. rubjonny
    disconnect the cable ends from the tower, see if its a stick problem or if the tower is sticky. the bearings inside the 02a towers can fail i assume 02j/s/m are similar?
  6. Sean_Jaymo Forum Member
    Lincolnshire
    I had this on mine. It was the pivot point for the vertical movement on the tower itself. It had been left stood for a while and this pivot gummed up. Took it all apart, cleaned and greased it and put it back together. Back to as new!
    But as Jonny says, disconnect the cables at the tower and see if it is the tower or the linkage.
  7. Danallkins
    Deal, Kent
    Replaced the cable bushes and all was good with the gearstick. But when all back together there was no change.
    So I have brought a new spring from VW (48p bargain!)
    I have taken is apart so far but not sure how to get the pin out for the spring.
    I've taken the clip off the end (1)
    but how do I slide the bar out or remove the spring from (2) ?
    Cheers
    Dan
  8. GVK
    The spring looks ok?
    I'd expect the 'legs' to be snapped off it.
  9. GVK
    Should have asked, is the lever stiff across the neutral gate (left/right) or 'floppy' and not springing back into the centre?
  10. Danallkins
    Deal, Kent
    It's 'stiff' just sticks where you leave it
  11. GVK
    Have you disconnected the cables from the gearbox end and checked if the gear lever then feels normal?
  12. Danallkins
    Deal, Kent
    When I put the new cable end bushes I had them disconnected, it moved ok and was centre I think!?!
  13. GVK
    With the cables disconnected from the gearbox if the lever springs back as it should, the fault is in the shift tower on the gearbox as mentioned above.
  14. Danallkins
    Deal, Kent
    Thanks for your help gents... I will get on to that today.
    Is the tower easy to take apart and check?
  15. Danallkins
    Deal, Kent
    Still not centring with cables off the box :-(
  16. tshirt2k
    tshirt2k Forum Junkie
    Herts
    Lift the gaitor and see if spring is in place ok.
  17. Danallkins
    Deal, Kent
    Yep. New spring in as well [:s]
  18. tshirt2k
    Herts
    Must be a cable issue.
  19. Danallkins
    Deal, Kent
    I've not heard of the mk4 having trouble with the cables... maybe I will jack it up and see if I can get some white grease on 'something' to free it up?! [8(]
  20. tshirt2k
    Herts
    If the cables are disconnected from the tower an the shifter has been checked. Only leaves cables.
    Sent from my GT-P5210 using Tapatalk
