Gearbox Housing - how did this happen?
Discussion in 'Mk4' started by tsutton, May 15, 2017.
  1. tsutton Forum Member
    I'll let the photo tell you the story. :)
    So... any ideas how this happened?
  2. Savagesam
    That doesn't look very happy!
    Possibly diff rivet gone?
    Martin will know!
  3. scalbaum New Member
    Is this a close ratio gear box from the mid 80"s? This happened to mine at about 75,000 miles. The diff pinion shaft hammers it way through the big rivets holding the ring gear on. VW left off the snap rings on the diff pinion shaft as a cost shaving measure
  4. Toyotec
    Diff rivets.
  5. MUSHY 16V
    aberdeen
    yip diff pin worked it's way through the top hat on one of the two rivets that hold it
    The diff pin actually has a circlip grove ffs
