Gearbox oil drain ? If not what is it?
Discussion in 'Transmission' started by mrglee, May 24, 2022.
  1. mrglee Forum Member
    IMG_20220524_153826.jpg I loosened off this (above) thinking it was the drain plug what's it for ?
    Drain plug bottom right what is it top right.
    Probably locates something inside the gearbox.
    The 17mm hex is the drain plug
  3. mrglee Forum Member
    Thanks Just found out its something to do with reverse on strip down only moved it a little done back up will leave it alone.
  4. GVK
    Holds the detent plunger into the shaft, dont remove it!!!
    KeithMac likes this.
  5. KeithMac Forum Junkie
    Kazakhstan
    We had a bloke in last week, with a detent spring and plunger in his hand.
    Was absolutely adament he'd undone the right plug to drain the oil out of his motorcycle even though he's lost all gears since.
    Couldn't talk any sense into him and gave up trying in the end!
    GVK likes this.
