Golf MK2 abf 16V agreed valuation policy
Discussion in 'Insurance chat' started by Chrisrpal, Apr 13, 2012.
  1. Chrisrpal Events Team
    Hi Guys,
    My Golf MK2 GTi which has had a full rebuild including the list below. The car was off the road since 2009 and Greenlight Insurance would no longer insure my golf because the no claims runs out after two years. I luckly managed to get insurance from Adrian Flux and mirrored my exisitng no claims from my nissan which has maxium no claims.
    My golf has had a agreed valuation of 3500, is that too low considering the the specifications list below?
    Engine
    Fully Rebuilt 2L 16V ABF engine
    ABF wiring loom
    ABF chipped ECU and transponer with key
    Lambda probe fitted to exhaust
    Piper X induction kit
    RED ignition leads
    TSR metal head gasket
    Polished and ported throttle body
    Recon gearbox 020
    Up rated Sachs clutch
    Mk3 weighted gear shift rod
    Manual adjust clutch cable
    New water pump and oil cooler
    Powerflow twin round 31/2 full stainless steel sports exhaust with x3 silencers and lambda boss, supplied and fitted by RSR
    Exhaust heat wrapped all the way through
    Re-sprayed front sub frame
    G60 rear Engine mounts
    Vibratech front engine mount
    Suspension/Steering
    GAZ Coilovers with adjustable dampering
    G60 top mounts
    Powerflex (rear axle beam and drop links) and flowflex bushes (everything else) throughout the car
    GAZ bump stop bushes
    Resprayed rear axle beam
    Powder coated front calliper carriers
    Eibach front and rear anti roll bars
    Brakes
    Golf G60 front calipers
    VW 22mm master cylinder
    280mm front cross drilled Zimmerman brake discs
    239mm rear cross drilled Zimmerman brake discs
    Pagid fast road brake pads
    New up-rated brake lines
    New flexi brake pipes
    Interior
    Golf G60 leather steering wheel
    Late mk2 red stripe GTi seats
    Rear head rests fitted to back seats (MJ Interiors supplied the fitting kit)
    Alloy golf ball gear shifter
    Pioneer DEH-P7600MP with six disc CD changer
    Exterior
    Shell fully re-sprayed in VW black 2011 by Chris Underwood motors, Bromley.
    Rear panel filled and smoothed
    De-badged front grill
    Vented wing
    Chrome bee-sting aerial
    16V rear light clusters
    Hella 16V tinted black front and side indicators
    16V badges on glove box (MK2), rear panel and front grill (Mk3)
    Big Bumpers
    VW green tinted windows throughout
    VW green top tint windscreen
    Wheels
    Falcon 195 45 low profile tyres
    16 BBS RX alloy wheels
    Security
    CAT 1 Clifford concept 600 alarm system with window roll up, alloy wheel sensors and 3 point immobiliser.
    Tracker (but no longer subscribed to it)
    De-locked front door handles
    Door jam plates fitted
    Added extras
    Electric windows
    Electric mirrors with wiring loom and switch
    Central locking
  2. M7R
    M7R CGTI Regional Host
    Nottingham
    tot up what its cost you, and have a look what others with the same kind of spec and re build are going for, you will never get back what it has cost (mine has a wedge worth alot more than I could ever sell it for) but it does have an agreed value at a sensible price that would allow me to buy another of about the same spec
  3. Chrisrpal Events Team
    Ok thank you for the advice :thumbup:
