Golf mk2 GTI gear linkage repair
Discussion in 'Transmission' started by Havsingh, Nov 5, 2020.
  1. Havsingh New Member
    Really!?! What a community!!!
  2. Havsingh New Member
    So that’s what I have left of mine ... glad to find a serious issue at least I know what the problem is...
  3. davidut5 Forum Member
    Romania
    There is one ball on the gear lever and another above the steering rack on the relay shaft.
  4. Tristan
    Yea, that's the way us OG club GTI guys are. Pm me your address.
    costel1969 likes this.
  5. Jon Olds Forum Junkie
    Going to copy the 'nylon ball' idea, thanks
    Jon
  6. Simon Peter Dodgson Forum Member
  7. Tristan
    34mm diameter, 27mm high with radiused "corners", I'm not sure if the centre is 10mm or slightly more. I left it a tight fit on the relay shaft pin, and put a dab of glue on, and it never moved. It can't fall off in place anyway.
    Sometimes the 34mm needs adjustment, I've seen them from 33.5 to 34.5 in the "gate". But with the nylon, a quick rub of sandpaper sorts it.
    Jon Olds likes this.
  8. Tristan
    Actually, from one motorsport fiend to another, send me your address, I've a different present for you.
  9. Havsingh New Member
    did we find Santa ?
  10. Tristan
    No, but Jon is a proper good egg.
    Savagesam and costel1969 like this.
  11. Havsingh New Member
    Arg! Guys how do I get past this bit! 45 mins can’t get any further any thoughts? Tried hot water to make it a bit more malleable..
    No idea why this image is upside down lol
  12. davidut5 Forum Member
    Romania
    Grind them down, and use bolts with nuts or hammer on new rivets. Mine came with two rivets.
  13. Savagesam
    Drill the rivets and pop new ones in, or clamp it in a vice
  14. Havsingh New Member
    Yeah, mine only came with 1 rivet which i assume is just a mistake from the seller. If bolt and nut works, ill do that!
  15. H8V
    h8v Forum Member
    I used a short bolt and nut, M5 I believe.
    It seemed better than hammering away with two rivets, and makes replacement the next time so much easier.
  16. Tristan
    I'm usually able to squeeze it in there with a little lube.
    Stop sniggering you bunch of perverts.
  17. Savagesam
    This was how I did my first one.
    drilling out 2 rivets takes like 10 minutes max and is so much easier!
  18. costel1969
    Finbar Saunders strikes again....
