GTI 16V ABF big problem
Discussion in 'Mk3' started by Pavol kmotorka, Jan 26, 2018.
  1. Pavol kmotorka New Member
    To begin with, I want to apologize for my English this is a google translator. I have a big problem with my golf 3g 16V. I do not know what to do in the end. The problem is that when the engine reaches 2700 rpm - 4000 rpm the engine starts to tear and work hard. Upon reaching 4000 rpm, the engine is as powerful as the new rack and the limiter
    Replaced parts:
    Spark plugs - denso, bosh and momentalne ngk R
    Ignition coil - ngk
    Ignition cables - ngk
    Hall sensor
    Sensor - suction air temperature, coolant temperature lambda probe bosh
    All vacuum hoses
    Fuel Pressure Regulator
    I do not know what I changed everything
    I did not get any difference
    It is finally delivered when the engine is completely cold so when it does not warm up so the car is normal.
    I would be very grateful and grateful for your help
  2. Toyotec
    Welcome to Club GTI.
  3. GregVR6GTI New Member
    would have been interresting to have a conclusion on that post as we are a lot to have this kind of trouble...
