GVK's "The 2 Litre 16v Thread" - Revived
Discussion in '16-valve' started by Mike_H, Dec 7, 2009.
Thread Status:
Not open for further replies.
  1. Mike_H Forum Addict
    A lot of the links on the old 2L 16v thread, originally posted by GVK, got broken over time, probably due to forum upgrades, so here's a new attempt at the same thing, as it was a fine useful thread when it was working.
    Please add your links, if they're not already included. the next set of posts are copied from the original, where the links still work, and I've edited out a lot of the conversation to get to the most useful info.
  2. Mike_H Forum Addict
    GVK's original post - unfortunately only one of the original links still works. I've removed the rest to avoid confusion.
  3. Mike_H Forum Addict
    EDIT:
    ABF/Late 9A/6A has 27mm diameter exhaust valves on a 27mm seat.
    KR/ Most 9A/6A has 28mm diameter exhaust valves on a 27mm seat (sodium cooled valves)
    ABF has one set of holes to bolt the dizzy on. Most(?) others have two, for greater adjustment.
  4. Mike_H Forum Addict
    Audi oil bracket issues
  5. Mike_H Forum Addict
  6. Mike_H Forum Addict
  7. Mike_H Forum Addict
  8. Mike_H Forum Addict
  9. Mike_H Forum Addict
  10. Mike_H Forum Addict
    Audi Engines
  11. Mike_H Forum Addict
  12. Mike_H Forum Addict
  13. Mike_H Forum Addict
  14. Mike_H Forum Addict
    Some more recent, equally useful threads:
    Toyotec's ABF in a Mk2 Thread
    http://www.clubgti.com/forum/showthread.php?t=133418
    Toyotec's Mk3 ABF Breathing Research
    http://www.clubgti.com/forum/showthread.php?t=199237
    Toyotec's 'Huffed' 2L 16v - the next level, and then some!
    http://www.clubgti.com/forum/showthread.php?t=114986
    Some gems from Nige P
    16v Cam Change
    http://www.clubgti.com/forum/showthread.php?t=184663
    16v Static Timing
    http://www.clubgti.com/forum/showthread.php?t=186796
    Chris edit:
    Fitting high lift cams
    http://www.clubgti.com/forum/showthread.php?t=91225
    Basics
    VW and Seat ABF differences
    http://www.clubgti.com/forum/showthread.php?t=168328
    2.0 litre block identification
    http://www.clubgti.com/forum/showthread.php?t=199516
    Head types, mixing and matching
    http://www.clubgti.com/forum/showthread.php?t=146656
    http://www.clubgti.com/forum/showthread.php?t=79185
    http://www.clubgti.com/forum/showthread.php?t=79515
    2-litre KR
    http://www.clubgti.com/forum/showthread.php?t=181165
    16v head cutaway thread
    http://www.clubgti.com/forum/showthread.php?t=193826
    16v block cutaway thread
    http://www.clubgti.com/forum/showthread.php?t=193695
    Alphabetical topic list
    ARP bolts
    http://www.clubgti.com/forum/showthread.php?t=61303
    Baffled sumps/crank scrapers
    http://www.clubgti.com/forum/showthread.php?t=101726
    http://www.clubgti.com/forum/showthread.php?t=86911
    http://www.clubgti.com/forum/showthread.php?t=76545
    http://www.clubgti.com/forum/showthread.php?t=119894
    Cams / timing:
    http://www.clubgti.com/forum/showthread.php?t=92312
    http://www.clubgti.com/forum/showthread.php?t=86157
    http://www.clubgti.com/forum/showthread.php?t=55761
    http://www.clubgti.com/forum/showthread.php?t=55136
    http://www.clubgti.com/forum/showthread.php?t=77097
    http://www.clubgti.com/forum/showthread.php?t=79593
    http://www.clubgti.com/forum/showthread.php?t=56450
    http://www.clubgti.com/forum/showthread.php?t=117027
    http://www.clubgti.com/forum/showthread.php?t=98526
    Cam swaps:
    KR cams in 9a
    http://www.clubgti.com/forum/showthread.php?t=167700
    KR cams in ABF
    http://www.clubgti.com/forum/showthread.php?t=83902
    Changing ABF cams
    http://www.clubgti.com/forum/showthread.php?t=42556
    9a on 288s
    http://www.clubgti.com/forum/showthread.php?t=90182
    Cams -wild:
    http://www.clubgti.com/forum/showthread.php?t=45285
    http://www.clubgti.com/forum/showthread.php?t=62076
    http://www.clubgti.com/forum/showthread.php?t=127870
    Crank sensors (ABF)
    http://www.clubgti.com/forum/showthread.php?t=162887
    Fuelling
    http://www.clubgti.com/forum/showthread.php?t=75391
    Gas flowing
    http://www.clubgti.com/forum/showthread.php?t=45461
    http://www.clubgti.com/forum/showthread.php?t=14468
    Head differences
    KR vs 6A head
    http://www.clubgti.com/forum/showthread.php?t=12624
    Headgasket differences
    http://www.clubgti.com/forum/showthread.php?t=140104
    http://www.clubgti.com/forum/showthread.php?t=121312
    http://www.clubgti.com/forum/showthread.php?t=182557
    http://www.clubgti.com/forum/showthread.php?t=182351
    Hybrid combinations
    KR head on 9A block
    http://www.clubgti.com/forum/showthread.php?t=175778
    9A head, ABF block
    http://www.clubgti.com/forum/showthread.php?t=166939
    KR head, ABF block
    http://www.clubgti.com/forum/showthread.php?t=177940
    http://www.clubgti.com/forum/showthread.php?t=200468
    Idle setting
    http://www.clubgti.com/forum/showthread.php?t=161364
    http://www.clubgti.com/forum/showthread.php?t=87992
    Ignition timing
    http://www.clubgti.com/forum/showthread.php?t=71520
    Inlet manifolds (42mm & 50mm)
    http://www.clubgti.com/forum/showthread.php?t=43412
    http://www.clubgti.com/forum/showthread.php?t=6324
    http://www.clubgti.com/forum/showthread.php?t=77871
    http://www.clubgti.com/forum/showthread.php?t=52545
    http://www.clubgti.com/forum/showthread.php?t=68765
    http://www.clubgti.com/forum/showthread.php?t=73441
    Intermediate shaft bearings
    http://www.clubgti.com/forum/showthread.php?t=56361
    Metering heads & fuel pressure
    http://www.clubgti.com/forum/showthread.php?t=20970
    http://www.clubgti.com/forum/showthread.php?t=46112
    Oil coolers
    http://www.clubgti.com/forum/showthread.php?t=7053
    http://www.clubgti.com/forum/showthread.php?t=73220
    http://www.clubgti.com/forum/showthread.php?t=72682
    http://www.clubgti.com/forum/showthread.php?t=77961
    http://www.clubgti.com/forum/showthread.php?t=80278
    http://www.clubgti.com/forum/showthread.php?t=67780
    http://www.clubgti.com/forum/showthread.php?t=179770
    Oil pumps
    http://www.clubgti.com/forum/showthread.php?t=197527
    http://www.clubgti.com/forum/showthread.php?t=179893
    Oil pressure readings
    http://www.clubgti.com/forum/showthread.php?t=61770
    http://www.clubgti.com/forum/showthread.php?t=122591
    Phenolic insulators
    http://www.clubgti.com/forum/showthread.php?t=63771
    Rev limiters & removal
    http://www.clubgti.com/forum/showthread.php?t=129014
    http://www.clubgti.com/forum/showthread.php?t=129423
    http://www.clubgti.com/forum/showthread.php?t=157700
    http://www.clubgti.com/forum/showthread.php?t=42265
    Rods
    6a rods same as KR?
    http://www.clubgti.com/forum/showthread.php?t=86602
    Throttle body
    http://www.clubgti.com/forum/showthread.php?t=44500
    http://www.clubgti.com/forum/showthread.php?t=146065
    Transplants:
    ABF into Mk1
    http://www.clubgti.com/forum/showthread.php?t=57148
    http://www.clubgti.com/forum/showthread.php?t=88593
    Windage trays
    http://www.clubgti.com/forum/showthread.php?t=4809
    WUR mod
    http://www.clubgti.com/forum/showthread.php?t=55045
    http://www.clubgti.com/forum/showthread.php?t=68346
    Target 180bhp+
    http://www.clubgti.com/forum/showthread.php?t=77371
    http://www.clubgti.com/forum/showthread.php?t=172582
    http://www.clubgti.com/forum/showthread.php?t=172588
    Target 200bhp+
    http://www.clubgti.com/forum/showthread.php?t=188950
    http://www.clubgti.com/forum/showthread.php?t=12053
    http://www.clubgti.com/forum/showthread.php?t=8666
    http://www.clubgti.com/forum/showthread.php?t=196591
    http://www.clubgti.com/forum/showthread.php?t=190724
    http://www.clubgti.com/forum/showthread.php?t=215409
    http://www.clubgti.com/forum/showthread.php?t=223248
    Target 210bhp+
    http://www.clubgti.com/forum/showthread.php?t=85123
    http://www.clubgti.com/forum/showthread.php?t=35339
    http://www.clubgti.com/forum/showthread.php?t=107899
    http://www.clubgti.com/forum/showthread.php?t=103553
    http://www.clubgti.com/forum/showthread.php?t=72122
    http://www.clubgti.com/forum/showthread.php?t=49301
    Other race engine type threads / analytical discussions
    http://www.clubgti.com/forum/showthread.php?t=191401
    http://www.clubgti.com/forum/showthread.php?t=187653
    http://www.clubgti.com/forum/showthread.php?t=182490
    http://www.clubgti.com/forum/showthread.php?t=173244
    http://www.clubgti.com/forum/showthread.php?t=186558
    http://www.clubgti.com/forum/showthread.php?t=156719
  16. altern8 Forum Junkie
    Cocos (Keeling) Islands
    nice work guys
  17. Mike_H Forum Addict
    Thanks... feel free to add more useful links, specifically related to 2L 16v engines, or 16v tuning.
    For anyone reading in, please don't post technical questions on this thread. Let's keep it as a reference list.
  18. VR6T
    VR6T Forum Member
    Aberdeenshire
    Just what i was looking for !!
  19. odub Forum Member
    Colchester, Essex
    great to have this all on one place again, thanks
  20. 2dubnick Forum Junkie
    Worcester
    well done guys, im sure this took along time to sort out:thumbup:
Thread Status:
