Hall sender question ?
Discussion in '16-valve' started by watercooled, Sep 17, 2021.
  1. watercooled Forum Member
    Nelson,New Zealand
    Can a fault in the hall sender effect tacho operation but still provide normal spark to the engine ?.
    Reason I ask is the tacho in my Corrado is all over the place and now not reading much above 1500- 2000 rpm ,as I have a spare ABF dizzy I don't need so thought I would fit the sender from that to my CIS one as I have to do the shaft seal anyway...worth a crack as they say ?.
    I think I read the hall sender is the same between the 2 but not the shaft ?.
    TIA,cheers.
  2. GVK
    Make sure its got the same trigger window.
  3. watercooled Forum Member
    Nelson,New Zealand
    Something like one is 2 window and other is 1 window (abf) ?,haven't check the KR on yet,cheers.
    kr dizzy is the same as 9a if that helps, so if you have a kr sat around swap whole thing and see if it makes a difference. though if the rev counter erattiv behaviour is being caused by the hall sensor, your engine would also run like arse
