Happy days
Discussion in 'General Chat' started by Belson231971, Jan 20, 2021.
  1. Belson231971
    Belson231971 Paid Member Paid Member
    The story so far
    My 1992 Alpine White VW Golf GTi 8v had been locked away in the garage for 2 years,and last year's Covid lockdown presented me with a great opportunity to get cracking with it.
    I purchased this car with many non-standard features, and am slowly rebuilding it back to how VW intended, The main non-standard item still to fix Is the fact that the previous owner converted it from Manual to Auto.
    Since owning it, I have carried out the following work
    Ripped out the old non-working alarm/immobilizer, and installed a new immobilizer
    Rebuilt the entire suspension to return to standard height (it had a complete lowered setup), new shocks, springs, bump stops, bushes etc
    Installed 4x BBS RA375 wheels with complete set of new rubber on each corner
    Installed new brake discs and pads on all corners
    Installed new Fuel pump accumulator and mounts, fuel pump and filter, as well as new fuel pressure regulator and vacuum hoses
    Full engine service, including swopping old cork rocker gasket for upgraded rubber option
    New Tie-rod ends and CV boots
    MFA computer sent away and fully refurbished by BilTechnik (Top service)
    Engine temp senders (both the blue and black ones replaced)
    New radiator, heater matrix and water hoses installed, including new water hose engine block flanges
    Headlight wiring loom complete with new relays upgrade
    Tailgate struts replaced
    New badges front and rear
    New side and front indicators swopped for clear versions
    Sunroof wind deflector removed stripped re painted and re-installed complete with new deflector lifter arms as the old ones had corroded away
    Fuel tank mounting straps stripped and painted
    New pedal rubbers and mats
    New Sony Stereo fitted and new Hertz Diece speakers mounted in front doors and dash, new speaker grills all round, small Alpine Sub connected to new Vibe Powerbox micro Amp in boot
    Various NOS panel trim clips and screws installed, E.G. Inner tailgate, door pulls, dash
    NOS Oil dipstick guide fitted to replace old cracked one
    New passenger electric window mechanism fitted
    New dummy switch covers installed where broken or missing
    New battery fitted October 2020
    New indicator/hazard relay
    Rear bumper had a big crack in it low down, as if the previous owner had reversed into a tow hitch or similar, I stripped it down, fibreglassed it, filled it and repaired it
    Stripped the headlights and cleaned the insides to restore the clarity of the glass
    She passed her MOT with 3 minor advisories on Saturday
    Items next on the agenda.
    I have a new Windscreen seal, and a windscreen on order, as the original one has a small crack in 1 corner
    As usual the drivers seat base bolster is worn through, I have a NOS foam replacement, and just waiting for the rainbow cover to come down
    Exhaust, it has a boy race back box (which back in the day I would have loved), I have a replacement stock item to fit
    Dynamat the interior
    Replace the brake lines and hoses
    Replace the engine mounts
    Replace the water pump and thermostat and whilst at it the belts
    Attack the bodywork
  2. cupracraig
    South West
    lovely project
    Belson231971 likes this.
  3. Jon Olds Forum Junkie
    Very nice, same colour as my mk2 tarmac rally car
    Jon
  4. Tristan
    Great work.
  5. costel1969
  6. Belson231971
    Thanks guys.
  7. dodgy
    Fantastic picture, nice to see a 5 door too.
