Having problems with Vag Com
Discussion in 'Vagcom / VCDS' started by ourkid, Nov 20, 2010.
  1. ourkid Forum Member
    I'm trying to set my injection quantity at idle but the vagcom keeps saying "Error - channel 001 not available". Anyone come accross this before?[:s]
  2. m1keh Forum Member
    Have you used a login code?
    So you go in
    Engine (1)
    Login (11)
    This code for engine login for injected quantity
    12233
    Adaption (10)
    Then change values as you wish.
  3. Crispy 8V CGTI Committee - Club Secretary Admin
    NW
    that one sounds about right
    you are using adaption rather than basic settings
    I've ran at both extremes of the adaption with bigger nozzles and noticed no difference!!
  4. ourkid Forum Member
    I got it working.It was originally at 8 so i tried dropping it (= more fuel,more torque,right?).The lowest i could get was 5.8.(started to smoke slightly).I thought i would get a bigger adjustment range than this.
    Curiously,using the hammer mod made very little difference between rich/lean knocking it all the way one side,then back again[:s]
    Anyway i've settled at 6 until i can road test it and monitor for smoke.
    thanks,
    Ade.
