Head gasket for overbored KR?
Discussion in '16-valve' started by Trev16v, Apr 11, 2005.
  1. Trev16v
    Oxfordshireland
    What head gasket do I use on a KR block that has been overbored to 83mm? Is there a standard gasket I can use, or do I need to obtain an aftermarket one?
    Thanks,
    Trev
  2. Andy947 Forum Addict
    Scotland, Aberdeen
    You clearly get the standard headgasket overbored aswell [:[]
  3. Trev16v
    Oxfordshireland
    Yeah right :lol:
  4. stevef Forum Member
    If you don't think that Andy947 is right then try a 9A/6A or ABF gasket?
  5. Trev16v
    Oxfordshireland
    Think that 9A, etc. are same bore diameter as KR though...?
  6. Hotgolf
    Smelly Cornelly
    Use the ABF metal gasket.
    They are better made and have a very fine rubber coating on them which helps its sealing properties, and require less of a rough finish to the head.
  7. iguana Forum Member
    Samoa
    ABF metal jobbie on mine.
  8. badger5
    nr Glos
    Eurospecsport list an 83.5mm bore head gasket for 16v
    How big a bore do you have?
  9. martyn_16v Forum Junkie
    behind the sofa
    9A/ABF are 82.5, KR is only 81
  10. Joe_G Forum Member
    Great Britain
    KR Bore is 81mm
    ABF/9A Bore is 82.5mm
    Oh what a bore [:[] :lol:
    Joe
  11. Trev16v
    Oxfordshireland
    It is going out to 83mm to give 1870cc (or whatever the exact figure actually is).
    Trev
  12. badger5
    nr Glos
  13. Trev16v
    Oxfordshireland
    Just dragging this thread up again because I could do with ordering the head gasket for this engine now, but I'm still not sure what to get.
    I'm hoping to get a suitable gasket from VW.
    Some of you guys have suggested an ABF gasket, which has a bore diameter of 82.5mm. Would this be okay to use with my block which has been bored to 83mm?
    Thanks
    Trev
  14. Hotgolf
    Smelly Cornelly
    The bore diameter of the ABF is bigger than 82.5mm. Thje bore of the block maybe 82.5 but I know the bore in the gasket is bigger.
    Just checked the 2 I have in the garage. One is a used ABF the other a 2E. Both have an 84mm bore. It would have to be bigger to allow for any indescrepency's.
  15. Trev16v
    Oxfordshireland
    Ah - thanks mate! Much appreciated :)
    Looks like I'll be getting an ABF gasket then. I guess GSF will be a good source - or would you recommend a VW one?
  16. Hotgolf
    Smelly Cornelly
    As long as it's the layer metal one then it'll be ok. It has a very thin coating of what seems like rubber which help with the sealing.
    I've been using one on mine for a little while with no problems at all.
    Will use on on the new engine too [:D]
  17. KeithMac Forum Junkie
    Kazakhstan
    I got Elring gaskets from GSF, looked well made and they haven`t failed yet (touch wood :lol:)
  18. Trev16v
    Oxfordshireland
    Thanks again gents. I have to make an order from VW anyway, so I'll pay through the nose for VW one.
  19. Trev16v
    Oxfordshireland
    I've got my ABF gasket now. There's nothing in particular I need to know about using a metal head gasket like this, is there?
  20. Trev16v
    Oxfordshireland
    The only thing 'wrong' that I can see with this ABF gasket I got from VW is the fact that one of the two 'pegs' does not align with a hole in the gasket. Should I just drill a hole for it? I also noted that some of the other holes for waterways / oil don't align perfectly - but it's okay, yeah?
