Heater Fan switch
Discussion in 'Electrical' started by Quiksilver, Jan 6, 2004.
  1. Quiksilver
    Quiksilver Paid Member Paid Member
    England
    Think i posted this on the old forum!
    But here goes!
    My heater only blows on the 3rd setting, i know the resistor pack has blown!
    Now can i replace this with a normal resistor and where is the resistor pack!
    Cheers
    Craig
  2. nogrille Forum Member
    Sao Tome and Principe
    resistor pack is on the side of the blower motor
    extract the motor and disconnect the plug - there's your resistor. Prise out with blunt screwdriver.
  3. Quiksilver
    England
    You talking about the bottom of the Heater unit.. undo the clip and twist clockwise thing!
    Or somewhere else!
    Do you know if its possible to place the just the resistor?
  4. nogrille Forum Member
    yes just the bottom of the unit. undo the clips and twist. it is possible to just replace the resitor (do not pay VW prices! use GPC or similar). remember to grease the motor (as per this months The Golf magazine - BUT DO NOT USE WD40 as the idiot suggested) as this is a contributing factor to resitor failure (too much resitance!)
  5. Quiksilver
    England
    Cheers matey..
    I'll sort out the replacement part first then i'll replace it!
    What would you use to Grease the bearing then!
