heel and toe ?
Discussion in 'General Vehicle Chat' started by Jeff_VR6, Feb 24, 2004.
  1. GVK
    Nope, I wouldn't say that. [xx(]
  2. vrbanana Forum Junkie
    Its not something Id recommend but with a proper brake flexi clamp (not a pair of mole grips) I think it would be ok done carefully. .
  3. vrbanana Forum Junkie
    Had one with a MC fault where the only way you could get a good pedal was to pressure bleed it, old res cap with a hose connector in it and aprox 5-8psi up the air line.
    Do you know how they fill them at the factory????? Done in seconds
  4. AndrewF Forum Addict
    i know what you should do....get a floor mounted pedal box! [:D]
  5. jake Forum Member
    I couldnt get the pedals right on my old 8v, but someone had adjusted the throttle pedal so it didnt hit the bottom stop at the same time as WOT was reached. I sorted that out and the pedal came right for h/t. just a thort.
  6. GVK
    We've got a pressure bleeder at work,I used it to change the fluid, but then bled it 'the old fashion way' :lol:
  7. I bleed mine with the faithful "Eezibleed" - but with the top screwed onto a gallon of fluid instead of the stupid bottle they give you......
    Never had any excess travel problems like you describe, sounds like the pushrod is too short (without being arsed to read the whole thread). You can clamp braided hoses fine, with a proper clamp or a pair of mole grips with sockets over the jaws.
  8. matt Forum Member
    if you can't heel and toe use your left it's nt just there as a clutch foot be brave use that
  9. Guests Banned
    i never really knew what the point of heal and toe was, now i know its the exact same thing i do on my r1 and dirtbike, its a lot easier to do with your hands
    sounds great too.
    oh well im going to see if my mk2 is up to it tonight :lol:
  10. PhatVR6 Forum Junkie
    I've never managed to master heel and toe at all, how the f8ck do you press the accelera tor when your foot is down there o the brake pedal?
    I can't even do it with the car stationary, let alone whilst braking hard into a corner!
    do you need big feet for this or what?
  11. pictonroad Forum Member
    It doesn't help you slow down quicker, the whole point is, you're NOT using the engine to stop.
  12. AndrewF Forum Addict
    sorry, you're wrong...the whole point is to use the engine to help you, but in a smooth fasion.
  13. pictonroad Forum Member
    Surely not, You bring the engine up to speed so you that the braking is with the brakes, not the motor.
    I went on a visit to Hethel and was taken out by two testers in Elises, they said that with a light Mid engined car you want the engine speed to match the gearbox speed, or you risk spinning if you're pushing it/its wet.
    When they H&T ed, as they released the clutch the engine speed was similiar or higher than the gbox speed, no engine braking.
  14. PhatVR6 Forum Junkie
    engine braking is bad. and you're pads are easier to replace then the clutch is....
  15. pictonroad Forum Member
    That's what I thought phat, I am fully ready to admit I don't really know sh1t about track driving but I am sure that H&T avoids engine braking. But then as I said, could be wrong....
  16. PhatVR6 Forum Junkie
    It does. that's what it's for.
    It's so the engine doesn't add more braking, thats the whole point of bringing the revs up, so when you let the clutch out the engine is at the right speed. otherwise, the engine will be idling, and when yo engage the clutch, the action of the slow engine engaging with the fast gearbox causes the front of the car to dip which could upset the handling.
    well, in theory. never had a problem with it myself, and I never bother to double de-clucth or left foot brake, or heel and toe. I just make a mess when ever I do it, an do really jerky braking.
    I need to go one one of those race driving days.
  17. pictonroad Forum Member
    I could sort of do it in my clio but the pedals in the golf are at diff heights and it's hard [:$]
    I was practising in the golf and when i pushed the brake pedal off centre the pedal rubber slipped off, seems like it had been held on by goodwill alone. Gave me the willys I can tell you.
  18. Guests Banned
    well i know that on my bike it stops the jerking from the engine which can cause the back end to step out.
    if you coming into a roundabout fast with rear wheel drive (speaking from a bike rider point of view) and you dump it down a gear the back can step. but blipping the throttle it makes the engine change down smoothly and the back doesnt twitch or step out.
    so maybe its more for rear wheel drive cars?
  19. AndrewF Forum Addict
    i know what i mean, but i can't think of a way to explain it accuratly.
    lets just say that a formula first car stops a hell of a lot quicker with h&t than without it.
  20. pictonroad Forum Member
    Can't argue with that :lol: :lol:
