Helix clutch - an update
Discussion in 'Transmission' started by Tubthumped, Feb 4, 2005.
  1. Golden Forum Junkie
    Tub it seems I've missed something, what 3 things have all gone wrong? I know your real main oil seal went but what else?
  2. GVK
    Rear main, helix paddle clutch disc fell apart and a standard clutch lasted 28 miles of sub 3k driving [:s]
    I still can't get my head around Tub actually driving like that for 28 miles :lol:
    Two-speed Tub - Flat out, or parked :lol:
  3. Golden Forum Junkie
    When you say the Helix fell apart, was that just Tubs odd noise?
    Also when the standard clutch went what failed, did it just wear out?
  4. Tubthumped Forum Junkie
    Hebden Bridge
    I had the gearbox built up with the ATB and 3.94 final drive. I decided at the same time to fit a Helix group N pressure plate and 4 padel cerematellic clutch. The flywheel is lightened, and the flywheel and pressure plate are balanced together.
    (So, new parts fitted where: gearbox (atb + FD) group N pressure plate, 4 padel clutch, flywheel.)
    The helix had that 'funny noise (in a previous thread asking about the rattle)' from a minute or so of it being started up the first time on axle stands.
    Helix have told me that what failed on the unit would have caused that rattle, and would be caused by:
    They also said that it will have been caused within quite a short time of the unit being started the first time.
    At the same time as this happening my rear crankshaft seal went - as we know it had no signs of damage or wear, and was still supple - but was leaking.
    The seal was replaced, and an LUK clutch kit fitted. After 28 miles this completley failed. Driving at less than 30mph is simply stopped transferring drive to the wheels. And clutch pedal felt as though there was little to no resistance against it. Car will go in and out of all gears, clutch pressed or not.
    Edited by: Tubthumped
  5. TIM
    Tim Forum Addict
    doesnt sound good mate hope you get it sorted,
    tim[8(]
  6. Golden Forum Junkie
    Tub where was the bitting point with the Luk clutch and can you remember how much of the clutch cable thread was showing?
  7. Tubthumped Forum Junkie
    Hebden Bridge
    There was lots of cable showing on both the Helix and LUK clutches - much more than i've ever had before.
    Biting point felt 'normal' after the adjustments.
  8. Golden Forum Junkie
    When you say "more cable" do you mean physically more cable exposed down to the clutch arm or do you mean more of the inner threaded part of the cable showing?
  9. Tubthumped Forum Junkie
    Hebden Bridge
    More of the threaded part is visible. I had to wind loads out to get the clutch feeling right.
  10. Golden Forum Junkie
    More of the threaded part would be normal for a new clutch.
    I can think of a few reasons why the rear main and Helix could've gone if the Helix was faulty but not the standard clutch.
    Did the Luk clutch engage smoothly?
    *a small note, the Sachs unit has a better design to the Luk*
  11. Tubthumped Forum Junkie
    Hebden Bridge
    LUK seemed fine - although it was slipping from installation. This was put down to small remains of oil on the flywheel.
    I can't say that the LUK and the Helix have both failed in the same way, for the same reason. But it seems a coincidence that it's all happened at the same time.. [:s]
    As a precaution Martin is gonna check all the gearbox side of things.
  12. Golden Forum Junkie
    I take it you did your best to clean the flywheel before refitting it?
    The only thing I can think of is that the Luk clutch jammed on the input shaft splines.
  13. Tubthumped Forum Junkie
    Hebden Bridge
    Flywheel was cleaned up by Jody at MidVW.
    He said there where small traces left in the surface, but nothing too serious and it should be fine after a few miles careful driving.
    Do you think there could be a problem elsewhere thats causing the same things though?
  14. mk1. Forum Junkie
    when fitting the g/box is it going straight in or are you having to wresle it in putting strain on the input shaft?they can be awkward especialy if fitting by yourself
  15. Tubthumped Forum Junkie
    Hebden Bridge
    I normally get them in quite easy to be honest - 2 of us with decent lifting gear and experience of my gearbox :lol:
  16. Golden Forum Junkie
    So I take it the Luk clutch is out Tubs?
    Have you got any pics or could you describe it's condition?
  17. Tubthumped Forum Junkie
    Hebden Bridge
    The LUK is still on the car mate.
    I would take it out today if it stopped raining [:x]
  18. Golden Forum Junkie
    My initial thinking is it could've been the Helix that knackered the rear seal. If part of it had fallen apart it may have caused a side load from being out of balance but the faliure of the Luk unit is baffling.
  19. Tubthumped Forum Junkie
    Hebden Bridge
    So, there could be some hope if the LUK failure is totally un-related to the Helix one....?
  20. GVK
    I'm still not ruling out a possible centre main failure causing all these faults, Mattd's car had this happen in the summer, I hope it isn't tho in your case Tub!
