Help Please Golf Mk5 1.4 Petrol 2004 , Problems With Abs Controller Unit
Discussion in 'Mk5' started by spfera, Oct 28, 2014.
  1. spfera New Member
    i need to know what the numbers and letters mean , i want to buy a new controller module , but dont know wich are the important codes that need to be the same !!!
    i havr found some on ebay but the numbers aint all the same
    thanks for any help[​IMG]
  2. Trev16v
    Oxfordshireland
    I'm guessing that you'll see an OEM part number and then the VW part number, and you'll want to match both up. Can you post up a photo of what you see on your ABS controller? I have a MK5 of the same year so I could look at mine tomorrow and give you some guidance if that's any help.
  3. EZ_Pete
    EZ_Pete Forum Junkie
    Under Bonnet, nr Abingdon
    This may be completely irrelevant, but have a quick glance at this thread from Briskoda.net. Lots of Polos and Fabias of the same era as your Golf have ABS lights pop on, and garages offer to charge several hundreds to fix what turns out to be a fuse that has failed/cracked in a box above the battery... Worth a quick look maybe?
  4. Trev16v
    Oxfordshireland
    Pete, I actually had exactly that happen on Lucy's Toledo the other week! I was all geared up to change the ABS unit, and then I read that the particular fault code was often caused by that fuse above the battery. Cleaned it up, reset the code from VCDS, and the fault has never returned.
  5. spfera New Member
    You look in to the fuse , tahnks ppl, by the way i did try to load a picture but its blank !!
  6. spfera New Member
    The problem its i cant find 1 thats exactly the same on all numbers and letters too, i will try to up load a picture again , the last one come up blank ! Lol
  7. spfera New Member
    I WILL look in to the fuse , thanks ppl, by the way i did try to load a picture but its blank !!
  8. Trev16v
    Oxfordshireland
    Tried to reply to your PM but your inbox is full.
  9. spfera New Member
    only 2 on my inbox mate !
  10. spfera New Member
    i foud this help on here but have a problem , a do folow this >>>
    . Albums can be created by visiting the User Control Panel, and clicking on the 'Pictures & Albums' link, and then clicking on 'Add Album'.
    i go to user control , but cant find the picture and albums settings to creat a new album , !!!!
  11. WillG
    WillG Forum Member
    Use photobucket.com or imgur.com to host files then use insert image when you post.
  12. spfera New Member
  13. rubjonny
    1K0907379K has been superceeded by 1K0907375K, and 1K0907375K is also a replacement for 1K0614517H and 1K0614517J. It's for front wheel drive vehicles with PR code 1AT which means 'for vehicles with ESP' if that helps :thumbup:
  14. spfera New Member
  15. spfera New Member
  16. benthejettaman Forum Member
    some where in the uk
    why do you need one, if you have the brake pressure sensor fault then vw will repair it under good will
