Help with a couple of bits of my cars service history?
Discussion in 'Mk5' started by 1990, Apr 29, 2015.
  1. 1990
    1990 Paid Member Paid Member
    Rochdale, Lancs
    In the pile of receipts are a couple of bits I was wondering about.
    The first is 06F 198 119 A - Repair kit. That was fitted along with water pump, chain and tensioner. Any idea what it is?
    The second is 06F 109 102 B - Camshaft. Is that a direct replacement or upgrade? That was fitted along with S06F 109 088 J - Adjuster.
    Thanks
  2. nealey Forum Junkie
    The repair kit will more than likely be a cam belt kit at a guess
    1990 likes this.
  3. rubjonny
    You guess right, cambelt kit inc tensioners, replacement nuts, bolts, roller etc.
    06F109102B is an exhaust cam for an AXX MK5 golf code engine amongst others. 06F109088J is a camshaft adjuster for a BLX, BLY and BLR engine. The AXX adjuster assembly appears to be sold as 1 piece, though when you actually look inside the kit it includes the 06F109088J part number so I guess you actually can change this part by itself.
    Whats the year/code of your car so I can check the parts above against it? I picked 04 Golf at a guess :lol:
  4. 1990
    Rochdale, Lancs
    It's a 55 :thumbup:
