Home Made Lathe
Discussion in 'Tools, Equipment & Fasteners' started by Dave, Nov 7, 2010.
  1. Dave
    Sligo, Eire
    Today, 'I ar' been mainly making a 'Lathe''.
    The two machine vices, I made as an apprentice, at Laycocks, in 1966.
    The chuck is from a 45 years old 'WOLF' drill.
    The bench grinder is about 40 years old.
    The block of wood, 'bed frame', is 12" x 8" Douglas Fir.
    Just need to make a tool post, and turning tool!
    Ha! How do you fix the chuck to the drive output?
  3. Dave
    Sligo, Eire
    Turns out, by luck, that B & D, are so cheap and nasty, that they used a 3/8" thread on the grinder shaft!:thumbup:
  4. MUSHY 16V
    aberdeen
    would you like a turning tool or two
    should have some spare in my tool box
  5. benny Forum Member
    Just need to knock up some 'Myford' stickers, job's a good un!
    Big fan of your work Dave :thumbup:
  6. matthew85 Forum Member
    Ha that's mint!
  7. Dave
    Sligo, Eire
    Ta so J.
    I was intending to make some out of HSS drill bits.
    Would quite fancy a small triangular tipped Carbide tool. Must be a removable tip though, as I don't have a 'green' wheel.
    I have not set up, or used a lathe, for about 40 years! Last time was when I used to set up the J Type Overdrive annulus line at Laycocks. I did it for about six months.
    I still need to get a 240V speed controller sorted out!
  8. Dave
    Sligo, Eire
    Ta so!
  9. aidanb22 Forum Member
    Redditch, Worcs nr Birmingham
    What wattage is it?
  10. aidanb22 Forum Member
  11. Dave
    Sligo, Eire
    Ta so Aidan. 1.1 Amp. It stalls out with the least bit of load on the grinding wheel.
    I flipping well never thought of a dimmer switch! Thank you so much!:thumbup:
    ps. Screwfix won't deliver to Eire. But, I can soon find a dimmer somewhere around.
    pps. Volex may be owned by Crabtree. But, I can tell you, from years of experience, that it is not as good. That it why it is so much cheaper!
  12. aidanb22 Forum Member
    Looks naff from the front I will agree, but the dimmer switchgear has crabtree written on it! Maybe they come straight from the rejection pile!
  13. Dave
    Sligo, Eire
    OK Aidan. Thanks for the heads-up. I will look at the back of any dimmers that I find!
    Once upon a time, I only used Crabtree. These days I only use MK. Can't find Crabtree easily in Eire!
    ps. Once upon a time, when I had cash, I employed an Electrician to re-wire my 400 years old cottage in Derbys. The wiring was lead cased it was so old. He fitted Volex, even though I had written a spec. stating that only Crabtree should be used. I did not pay him 'til he had changed everything to Crabtree!
  14. Dave
    Sligo, Eire
    I made a turning tool from an HSS drill bit today. Burnt out very quickly.
    Oilite only recommend Carbide or Diamond.
    Mushy. Have you got a Diamond tool you don't need? 0.1mm/0.2mm tip rad!:thumbup:
  15. mec82 Forum Member
    thats look really good, for the next one how about making a milling machine from a pillar drill!
  16. Dave
    Sligo, Eire
    Sort of.
    I have a Lidl pillar drill thingy, that you fasten a normal drill into. The bracket for the drill has broken.
    I also have a 20,000 rpm router head, the base of which has broken.
    Add the two together + the two-vice traverse system = milling machine.
    Great minds think alike!:lol:
  17. Brian.G
    Brian.G Forum Member
    West of Ireland
    Dave, Im Impressed. I should let you know that I have a spare http://www.lathes.co.uk/raglan/page14.html
    In good shape missing a tool post and tail stock, Id value it at around 100-150euro, if you have anything you would consider trading its yours. I have two other lathes, Bridget, and just two hands.
  18. danster Forum Addict
    Another suitor for Miss daved perhaps? :lol:
  19. Brian.G
    West of Ireland
    :lol::lol: Its a realllllllllll sweet lathe now:thumbup::lol:
  20. danster Forum Addict
    I will accept a small commission from you if everything goes to plan with your deal with daved. ;)
    How about you "cast" me the perfect woman? :p
    At least she will be hot for a certain length of time. :thumbup:
